Issue getting XFX HD5770 to work
Radeon
Graphics
chcardin
February 22, 2011 2:36:58 AM
Hello,
I have a system sutup running an Intel DP55KG with the new BIOS 5921, 4 X 2GB Corsair paired memory and a Zalman 850W PSU. If I use a low grade GPU (EVGA 9800GTX)the system runs fine, but when I install the XFX HD5770 I get the well known E6 error code. I have cleared the CMOS but I still get the E6 code. Does anyone have this configuration running and how did you get the video card to work?
More about : issue xfx hd5770 work
sapreaper
February 22, 2011 5:04:40 PM
sorry i don't have the answer directly, but i cannot see power as an issue considering the 5770 uses far less wattage than a 9800GTX does.
I run an HD5770 1GB ddr5 with a Corsair 650w with no issues. See sig
I guess it could be one of those Intel/Ati/Versions of drivers/firmware compatibility issues??
*ok i think i fixed my sig now
m
l
- will xfx HD5770 work without 6 pin power supply - Forum
- My new XFX HD5770 won't work with my computer. No boot, no POST. - Forum
- GTX 660 Ti or two (2) XFX HD5770 in crossfire. - Forum
- Getting 8GB of OCZ PC6400 DDR2 to work with my XFX 750i SLI motherboar - Forum
- Will XFX HD5770 be a wise chioce for 1024x768 resolution monitor..??? - Forum
sapreaper said:
sorry i don't have the answer directly, but i cannot see power as an issue considering the 5770 uses far less wattage than a 9800GTX does.I run an HD5770 1GB ddr5 with a Corsair 650w with no issues. See sig
If the mobo isn't providing adequate power to the PCI-E bus, then the GPU will not perform properly. Thus, the recommendation to check it. This is most likely NOT an issue of driver/hardware compatibility.
m
l
sapreaper
February 22, 2011 5:58:08 PM
COLGeek said:
If the mobo isn't providing adequate power to the PCI-E bus, then the GPU will not perform properly. Thus, the recommendation to check it. This is most likely NOT an issue of driver/hardware compatibility.understood.
it would just be odd that it is only occurring with the card that takes less power. I would say the card itself may just have an issue then. That is the only component that changed.
m
l
chcardin
February 24, 2011 4:39:33 AM
I have reseated the power connectors and the ploblem still exist. I went out and purchased a Saphire HD 5770 1GB DDR5 video card and the same error happens. I can understand the possible firware compatability issue but I have used a different system D945GPM to load the latest firmware on the GPU and the mobo has the latest BIOS loaded. So I am still lost on this issue. It is really strange the the card works on an older modo and not the DP55KG.
m
l
chcardin
February 24, 2011 1:58:53 PM
It was suggested in a previous thread to check for firmware compatability. I figured at this point I would try anything to make this work, so I updated the firmware on the video card. I had to update the BIOS anyway to get all 4 sticks (8GB) of memory to work. It was also suggested there may be a power issue but the other system this card works on only uses a 360W PSU with a Pentium D 960 3.6GHz dual core and 4GB memory. This system I am trying to get to work has a much larger PSU so the lack of power is not an issue.
m
l
Okay, I think I understand some of this.
1. You have updated the BIOS on your motherboard to get all of the memory to (8GB) to work properly. Are you using the version dated 30 JAN 2011? Link below.
2. The firewire thing is not relevant regardless of what another thread may have indicated.
3. You also updated the firmware on the video card. Where did you get this firmware?
4. Which PCI-E slot are you installing the video card into?
http://www.intel.com/p/en_US/support/highlights/dsktpbo...
m
l
sapreaper
February 24, 2011 2:44:25 PM
sapreaper
February 24, 2011 2:52:12 PM
chcardin
February 24, 2011 3:27:05 PM
Answer to questions
1) I got the latest BIOS from Intel version 5921
2) I got the firmware from my account on the XFX website
What I am starting to think that this is a video card memory compatability issue. Here is what works and what doesn't work
1) ASUS ATI HD4350 with 512MB RAM - works
2) eVGA GeForce 9800GT with 512MB RAM - works
3) XFX ATI HD 5770 with 1GB RAM - error code E6 (fails)
4) Sapphire ATI HD 5770 with 1GB RAM - error code E6 (fails)
Just a thought.....
Just a thought.....
m
l
chcardin
February 24, 2011 3:29:03 PM
Understood on all. Video card compatibility has nothing to do with motherboard compatibility. They are separate and distinct things. Try this as an experiment. Insert the GPU into the x8 slot and see if it will boot.
Also, switch PCI-E power cables (your PSU should have at least 2 of them). I would also suggest clearing the BIOS and setting to its default config as well
m
l
chcardin
February 24, 2011 10:05:36 PM
Okay here is what I did
1) switch the PCI-E power cable with a secondary one. On the Zalman all the cables are modular except for the main power and one of the PCI-E cables so I inserted the secondary PCI-E cable and plugged that into the video card and got the same error.
2) Moved the video card to another x8 slot and got a new error code E7
3) Cleared the CMOS and powered the system up again and got the same error code E7
4) Cleared the CMOS and move the video card back to the x16 slot and powered and got the previous error code E6
I put the eVGA GeForce 9800 GT back into x16 and the system came up
m
l
chcardin said:
Okay here is what I did1) switch the PCI-E power cable with a secondary one. On the Zalman all the cables are modular except for the main power and one of the PCI-E cables so I inserted the secondary PCI-E cable and plugged that into the video card and got the same error.
Good job being thorough. Have you contacted Tech Support at Intel? This is beyond bizarre at this point. Common GPU in a current motherboard with a common chipset.
Have you tried installing the 5770 with only 4GB as an experiment?
m
l
chcardin
February 24, 2011 10:40:49 PM
Yes I have had extensive conversations with Intel Tech support and they say it is not the mobo they say it is the Video card even after I tell them the XFX has been replaced twice and I have tried another vendor Sapphire they still refuse to except it could be the mobo. They also said the 4 sticks of 2GB memory should work too but it was not until I loaded BIOS 5893 I could do that. So I am not feeling to good about the Intel product line at this time.
m
l
chcardin
February 24, 2011 10:42:36 PM
My friend, I have never seen anything like this and know of no known incompatibility issues here. Intel's response is simply irresponsible and simply can't be true (that this is a GPU issue). Too many Intel boards out there with ATI GPUs and the 5770 is one of the most popular. Do you have the option to return the mobo?
m
l
chcardin
February 25, 2011 12:57:05 AM
Do you know anyone with a 5770 (1GB) or better GPU that you could swap for troubleshooting purposes with?
Does you mobo BIOS have any specific GPU/video related options?
I am out of ideas and I tend to lean towards an issue with the mobo as you have seen the GPU work in other systems (when you flashed the BIOS).
m
l
chcardin
February 25, 2011 4:13:05 AM
Well what I need is someone with this mobo and a video card that matches mine. I have two of these HD 5770 cards. I was hoping someone would come fourth and say they have this configuration working and if anything what they did to make it work. Well back to hunt to find the answer. I am about to swap it out with a eVGA classified 200 mobo, but it sure has tainted my feelings about Intel.
m
l
chcardin
February 25, 2011 2:14:05 PM
Okay I did some investigation and this model Intel board impliments UEFI and that feature is disabled on this board. I also discovered that all my Intel DP55 series will not support this level of video card. I tried both the XFX HD5770 and the Sapphire HD5770 on the following system boards
DP55KG
DP55WG
DP55WB
and non of them would pass post, so this make it even more strange
DP55KG
DP55WG
DP55WB
m
l
chcardin said:
Okay I did some investigation and this model Intel board impliments UEFI and that feature is disabled on this board. I also discovered that all my Intel DP55 series will not support this level of video card. I tried both the XFX HD5770 and the Sapphire HD5770 on the following system boardsDP55KG
DP55WG
DP55WB
This is truly bizarre. Thanks for your diligence. I can't believe that Intel would allow mainstream mobos to be released with such a limitation. Something just isn't right here. Good luck, my friend!
m
l
You know, this is truly odd. I looked at user feedback for all 3 models chcardin listed at Newegg and saw nothing that would indicate this problem. There were several complaints regarding quality issues, but not any that I saw regarding GPUs. Many listed GPUs that had 1GB (or more) and seemed to work.
This is a mystery to me.
m
l
- SolvedWill CORSAIR CX430 [430W] PSU runs my XFX RADEON HD5770 card ?? Forum
- Radeon HD 7750 issue getting 6 monitors to work Forum
- SolvedHD5770 Gigabyte or XFX Forum
- SolvedMSI R5770 Hawk or XFX HD5770 Forum
- SolvedHD5770 XFX XXX Puchase help Forum
- SolvedXFX R9 280X crashing issue Forum
- SolvedXFX R7850 PCI resolution issue Forum
- XFX Radeon HD5770 Grey screen, no video Forum
- Solvedgetting new PC and wondering if i will be able to overclock it without issue. Forum
- 1600mhz RAM in 1333mhz(OC) motherboard - Having issues getting it to work Forum
- Solvedwhy is my EVGA GTX 780 SC with ACX cooling getting worse fps in battlefield 4 then my XFX R7790 (ghost thermal design) Forum
- SolvedWould this pc spec list im getting work nicely? Forum
- SolvedWhat is the difference between XFX 550w Core Edition and XFX 550W TS Gold? And do they work with GTX 770? Forum
- Worth Upgrading XFX HD5770? Forum
- SolvedHaving Trouble getting Video Signal from Brand new XFX Radeon R9 290X Graphics Card [solved] Forum
- More resources
