I am currently in the middle of m first build, for the most part it is going well just a few snags i ran into.
1) The power switch, LED and reset plugs from my case have different color wires, in the MOBO manual it refernces lining up the +, -, & ground. My question is what are the colors that correspond with this? I have blue, white, brown to choose from. Power switch is white and brown, Power LED is blue and white.
2) do I connect the SSD to the MOBO or to the hardrive? Manual does not indicate one way or the other.
3) Can the SSD & Hard drive be hook up to the power supply? What is the benefit?
