I had this computer built and received it about 2 weeks ago. When I try to power up the Ram check light comes on then goes back off the fans rev and then it repeats. If I unplug it let it sit for a few minutes then plug it back in, it might boot. When it does come up it is a crash monster. I get the BSOD about every 5 minutes and for some reason it is always a different crash reason. Any help you can give would be appreciated. Thought about asking for a mother board change but not sure.
CPU: AMD Phenom™II X6 1100T Six-Core CPU w/ HyperTransport Technology
FAN: XtremeGear Liquid Cooling System 120MM Radiator & Fan (Enhanced Cooling Performance + Extreme Silent at 20dBA) (Single Standard 120MM Fan)
HDD: 1TB SATA-III 6.0Gb/s 64MB Cache 7200RPM HDD (Single Hard Drive)
MEMORY: 8GB (2GBx4) DDR3/1600MHz Dual Channel Memory Module (Kingston HyperX)
MOTHERBOARD: Asus M4A87TD EVO AMD 870 Chipset CrossFireX Support DDR3 Socket AM3 ATX w/ 7.1 Audio, GbLAN, IEEE1394a, USB3.0, SATA-III, RAID, 2 Gen2 PCIe, 1 PCIe X1, & 3 PCI
NETWORK: Onboard Gigabit LAN Network
OS: Microsoft(R) Windows(R) 7 Home Premium (64-bit Edition)
POWERSUPPLY: 700 Watts - XtremeGear Power Supply - SLI/CrossFireX Ready
USB: Built-in USB 2.0 Ports
VIDEO: AMD Radeon HD 6970 2GB GDDR5 16X PCIe Video Card (
