I Got a i7-950 OC to 3.84GHz at 1.225v as will as with RAM OC to 2009MHz at 1.6v on a timing of 9-10-9-24... When I Enabled HTT, it shows 4 Virtual Cores in Windows but when I looked at my HWMonitor, it shows 2 Cores(Temp reading)... When I Disabled HTT, it should 4 Cores in TaskManager and HWMonitor(Temp Reading)... Does anyone know why it's not showing all 8 Virtual Cores... It seems to bee stuck on 4 Virtual Cores... No matters what I do, When I Enabled HTT, 2 cores got disabled or is like I Selected 2 cores to run in BIOS, When I Disabled HTT, It shows all 4 Cores... Anyone knows why it's not showing all 8 Virtual Cores?
NOTE: Dont ask why I want all 8 and yes I know that it increase heat and IDRC(I Dont Really Care) about it so dont ask stupid question why and why and why I want to do this, I just need help...
Thanks!
Thanks!
