Sign-in / Sign-up
Monitor says "No Signal" but recognizes connection
  • Graphics Cards
  • Connection
  • Monitors
  • Graphics
Last response: in Displays
February 23, 2011 4:11:50 AM
Hello,
Just finished building a new PC. My monitor recognizes that there is a connection, but does not get a signal. Everything seems to be powering up and working just fine from what I can tell--the fans on the graphics card are on. No beeps at startup. Any ideas?
More about : monitor signal recognizes connection
February 23, 2011 4:27:40 AM
im having a similar problem with my computer only recognizing my mother boards video card and every time i plug my monitor into a dvi port it goes into standby.
m
l
February 23, 2011 4:38:30 AM
nintom said:
Hello,
Can you hook up the pc you used to access tomshardware to the monitor? if that still says no signal then It's a problem with your monitor.also if you have an extra monitor lying around try hooking up your rig to that.
m
l
February 23, 2011 5:02:25 AM
Yes, I can hook up the monitor to the laptop I'm using to post this, and it works just fine. I don't have another monitor that I can plug into my rig--but it's got to be the rig since the monitor works for sure.
m
l
February 23, 2011 4:03:25 PM
Have you tried plugging the monitor into the other outputs on the GPU? Did the MOBO come with onboard GPU?
m
l
February 23, 2011 4:04:03 PM
Bump... any other ideas? I'm completely at a loss.
Thanks!
m
l
February 23, 2011 4:06:41 PM
I don't think there is an onboard GPU with the mobo. I have tried both DVI outs on the GPU. There is also another one--I think it's a mini HDMI out. I don't have a cable for this so I haven't tried it.
m
l
February 23, 2011 4:19:17 PM
Then I would re-seat the GPU, check the power inputs, try a different PCI-e slot, and finally try the GPU on another computer. No go on all of the above = RMA
m
l
January 31, 2012 6:50:37 PM
nintom said:
Hello,
i actually just had the same problem... to me it seemed like a bios problem and I'm guessing it was. I removed the bios battery, put it back and then after boot the pc started trying to read bios and said no date set blah blah blah... butt it worked :)  I hope this helps.
m
l
