Ati 6850 - Problem
  • Graphics Cards
  • HD
  • ATI
  • Graphics
Anonymous
a b U Graphics card
February 23, 2011 2:20:24 PM
HI , I have recently upgraded from a ati hd 3450 to a hd 6850 , everything seemed to work well the first day , and some of the low overclocking i did went fine , the following days all started to mess up , i restored the custom clocking ot normal , as i though that was the case , the screen twittered , and black lines flashed until the screen crashed , that was fixed after you rebooted the computer , no games could be played as they got stuck and a little triangle shows up with an exclemation mark in th windows bar. what could be the problem ? i reinstalled the driver but that only helps for about a day , ohh and while watching pictures , you can see red and blue pixels moving around,
More about : ati 6850 problem
February 23, 2011 2:49:00 PM
might be an overclocking failure,i would say to reset bios chip.another thing that you should consider that overclocking sometimes does makes system completely overhaul.
