In an 800D with i7 2600K @ 5Ghz+ and two 580 FTWs?
Radiator
http://www.newegg.com/Product/Product.aspx?Item=N82E16835108098&cm_re=radiator-_-35-108-098-_-Product
Pump
http://www.newegg.com/Product/Product.aspx?Item=N82E16835108082&cm_re=swiftech_pump-_-35-108-082-_-Product
Reservoir
http://www.xoxide.com/swiftech-mcres-micro.html
Waterblock
http://www.newegg.com/Product/Product.aspx?Item=N82E16835108113&cm_re=1155_water_block-_-35-108-113-_-Product
With Feser tubes and liquid
thanks
Radiator
Pump
Reservoir
Waterblock
thanks
