i built my desktop over the past summer and it works fine except that when i command it to shutdown it goes through all the processes and then cuts video feed but it never actually turns off the whole system. When i try to turn it back on after eventually flipping the switch or holding the power button it gives me BSODs or it tells me windows didn't shut down properly and i have to reset the system several times before it will work. I have taken to just leaving it on all the time which wouldnt be a problem if putting it to sleep didn't do the exact same thing. video feed stops but the fans don't slow down and i can't wake it up, i just have to restart several times.
here are my system specs
MSI 790FX-GD70 Motherboard
AMD Phenom II X6 2.8 GHz Processor
8 Gigs of Patriot Ram (4X2)
2 ATI Radeon 5770s in crossfire
750 watt power supply
1TB barracuda hard drive
Win7 64bit
thanks for any help you can give
Win7 64bit
