Tom's Hardware > Forum > Digital Camera > Digital Camera General > What are accepted figures for signal/noise (SNR) and dynam..
Forum Digital Camera : Digital Camera General - What are accepted figures for signal/noise (SNR) and dynam..
Archived from groups: comp.dsp,rec.photo.advanced,rec.photo.darkroom,rec.photo.digital (More info?)
I'm converting my old analog scanning electron microscopes to digital/pc
based.
One of the important questions is how many bits of resolution ie: levels
of greyscale are required. I've heard the analog front ends of the
scopes have a maximum SNR of about 72 dB, or 12 effective bits, and to
give me some flexibility for digital image processing that's about what
I'll shoot for: a bit better if I can get it.
But on the other end of the scale, I'm wondering what are accepted
figures for signal to noise or dynamic range of various display
technologies, and of the human eye.
It seems to me the published "contrast" figures for LCD displays of
about 600:1 peg them at about 49dB dynamic range.
What is generally accepted for B&W film? Is it highly dependent on film
type and processing? Anyone know some typical figures for various
processes? Is "silver print," which in my mind is marked by high
contrast, a special technique or just a fancy word for black and white?
How about for CRT's? Deos it depend in part on the design and
construction of the CRT, and do dedicated monochrome CRTs have a greater
dynamic range for greyscale than color CRT's used to display greyscale
images?
And what about the human eye, for that matter? It's been suggested the
human eye has only about 6 bits or 36 dB dynamic range/SNR for greyscale
images. Is that about right? Bonus question: I know the sensitivity of
the human eye varies with color, being most sensitive at about 555 nM
green. How about dynamic range and SNR? Deos it vary with color, too?
Thanks!
-Jeff
Sponsored Links
> based.
--snip--
Most of what you ask I don't know, but what I _do_ know is this:
In infrared imaging (which is what I'm familiar with) you take as many
bits as you can get at the sampling rates you need -- this is currently
14 bit ADC's at 10MHz on high-end systems. Even so you need some
up-front gain selection (in the form of allowing the user to select a
few different integration times) to get the best picture for the
conditions. This data gets processed, gained up linearly or
non-linearly, possibly spatially and/or temporally filtered, then
presented to the user on video with an 8-bit DAC. Needless to say you
throw away a _lot_ of information when you go through the
user-presentation layer.
Tim Wescott
Wescott Design Services
http://www.wescottdesign.com
Reply to Anonymous
I am not certain about the technical data, you should ask some electronic
engineer, but it's very difficult to construct a lcd or tft scrren that can
compete a good crt, because the picture in the crt is made by tiny bits of
phosphorus struck by the cathod rays, also emitting their own light.Besides
that, crts have a developing history of more than 50 years.
Tzortzakakis Dimitri?s
major in electrical engineering, freelance electrician
FH von Iraklion-Kreta, freiberuflicher Elektriker
dimtzort AT otenet DOT gr
? "jeff miller" <cornheadorama@hotmail.com> ?????? ??? ??????
news:GyxSd.9722$DC6.4186@newssvr14.news.prodigy.com...
> based.
> images?
> Thanks!
> -Jeff
Reply to Anonymous
> based.
> images?
Man! you ask a lot of good questions! I suspect that many of the answers
are to be found in papers of the SMPTE.
I recall that the contrast between printer's ink and glossy paper is
about 10:1 and B&W prints on glossy paper are a bit better (but on
matte, a bit worse). The contrast ratio of newsprint can be as low as
3:1 before the ink starts to look gray. Discouraging, no?
Look at your TV screen when the set is off. No part of it gets darker
when the set is on, but it sure looks like it does.
Jerry
Engineering is the art of making what you want from things you can get.
Reply to Anonymous
Correction: 30:1.
Typical newsprint before the now-common biodegradable soy ink was 10:1.
Jerry
Reply to Anonymous
> Correction: 30:1.
Photographic paper can get to 2.0 od reflected, a range of 10 ^ 2 = 100:1.
I just took a measurement from a printed page on coated stock, it
yielded 1.27 => 1.3 => 10 ^ 1.3 => 20:1.
Nicholas O. Lindan, Cleveland, Ohio
Consulting Engineer: Electronics; Informatics; Photonics.
To reply, remove spaces: n o lindan at ix . netcom . com
psst.. want to buy an f-stop timer? nolindan.com/da/fstop/
Reply to Anonymous
>>Correction: 30:1.
Thanks for the reality check. The 30:1 figure was the best available,
typically found in (new) eye charts and photographic resolution targets
when I played with that stuff 40 years ago.
Jerry
Reply to Anonymous
Jeff miller wrote:
> I'm converting my old analog scanning electron microscopes to digital/PC
based.
> One of the important questions is how many bits of resolution i.e.: levels
> of grayscale are required ... the eye ... film ...
The eye is comfortable with a brightness range of ~50-100x in one scene
with no pupilary/retinal adaptation, 1000:1 is viewable without noticing
much adaptation - after images or time for pupil to adjust. The eye can
accommodate a brightness range from reflected starlight on a field
(remember clean air and no streetlights?) to sun on fresh snow (except
in extreme cases, mountains, clean air ...). This about a 25 bit/zone
range or ~32,000,000:1 and has no relevance to viewing a CRT.
Within a 2.0 OD range it can easily discriminate to .005 OD in the middle
of the range. However, OD is logarithmic and photocells and CRTs aren't.
Figure you will need about 12 bits for very good fidelity, but 8 bits
looks just fine on a CRT.
Numbers above are from memory, you should check with a good text on
human visual response if the values are important.
Negatives have close to no relation to photoptic response. Exposure
and development of film are such as to yield the thinnest (least dense)
negative that will yield a good print. This figure depends on scene
contrast, film contrast, paper contrast and the method used to image the
negative on the film.
I have to confess I don't see much relevance in all this to an SEM. All
you want is the range of signal that presently goes to the current
analog display and be able to accommodate that. 8 bits resolution should
be adequate.
Reply to Anonymous
In normal lighting, the cones on the retina can detect contrasts of aprox.
2% over a range of 2 orders of magnitude. Their dynamic range is closer
to 4 orders of magnitude, but their ability to differentiate shades drops
rapidly at the lower (darker) end of the scale.
A 13 or 14 bit (linear) number would cover the same range, with the same
(or better) ability to separate shades. (Aside: Computer displays manage
with 8 bits, partly because they don't have a contrast ratio of 1:10^4 and
partly because they are not linear.)
There's a lot of good stuff at
http://webvision.med.utah.edu/
and
http://faculty-web.at.northwestern [...] %20eye.pdf
The response of B&W film covers about 3 orders of magnitude. For B&W
paper, the reflectivity ratio between white and the deepest black is about
100:1. Ilford publish a lot of useful data on photographic materials at
www.ilford.com
-Tim
Reply to Anonymous
Yes. There's more light reflected from a lump of coal in sunlight than
from a bowl of snow indoors. The eye/brain isn't fooled.
For high-resolution work, we used to dye the emulsion black to avoid
exposing interior grains. After all, the image can't be in focus
throughout the emulsion depth. To make the film a little faster, we
would etch away the top few microns of the emulsion, leaving an exposed
layer of grains, like in sandpaper.
> be adequate.
The question of which 8 bits can be important. I can adjust images from
my 12-bit flat-bed scanner in ways that just don't apply to 8 bits.
Jerry
Reply to Anonymous
> be adequate.
But that is one of the attractive features of this group.
( OK, so I'm reading comp.dsp ;)
By reading one learns so much more than one narrow area of knowledge!
Reply to Anonymous
> [snip]
>> All you want is the range of signal that presently goes to the current
>> be adequate.
> Jerry
I think that touches on a question I raised in another subthread.
Why a *FAST* *16 bit a/d* ?
Would it not be more suitable to have 2 A/Ds in "parallel"?
A very fast 6-8 bit A/D for use while positioning sample.
A 16+ bit A/D for analytical output.
Caveat Lector ;}
Reply to Anonymous
"Jerry Avins" <jya@ieee.org> wrote in message
news:bvednWR1h9Qr4IbfRVn-uA@rcn.net...
SNIP
See e.g.
<http://web.mit.edu/persci/people/adelson/checkershadow_illusion.html>
Bart
Reply to Anonymous
In article <GyxSd.9722$DC6.4186@newssvr14.news.prodigy.com>, Jeff miller
> images?
As others have said, you should capture and manipulate your original images
at the highest bit depth you can handle, but what is usually transmitted by
TV companies, recorded on DVDs, or saved in JPG files for display on CRTs
is based on 8 bit linear coding after gamma correction, and it generally
looks just fine. i.e. 8 bits seems to be quite sufficient for display.
From personal observation, dynamic range of monochrome and colour CRTs are
about the same, though the detail resolution can be slightly higher on a
monochrome CRT displaying a monochrome signal.
Rod.
Reply to Anonymous
Richard Owlett wrote:
>> [snip]
>>> current analog display and be able to accommodate that. 8 bits
>>> resolution should
>>> be adequate.
>> from my 12-bit flat-bed scanner in ways that just don't apply to 8 bits.
>> Jerry
> Caveat Lector ;}
Hmmm.... I'd thought about that but not to those extremes: in fact it
makes much more sense at the extremes you suggest and I may well
incorporate the idea. It will also give me a chance to jump-start the
project before I have the funds for the higher performance A/D.
Interestingly enough the 16 bit 5MSPS sigma-delta A/D I was thinking
about has a 10MSPS "turbo" mode with 14 bit resolution.
This thread is providing some very useful information about SNR of media
and human eyes... keep it coming!
Reply to Anonymous
>>images?
> Rod.
Yes good point as there is no "dot pitch" issue.
-Jeff
Reply to Anonymous
See:
Notes on the Resolution of the Human Eye
How many megapixels equivalent does the eye have?
The Sensitivity of the Human Eye (ISO Equivalent)
The Dynamic Range of the Eye
The Focal Length of the Eye:
http://www.clarkvision.com/imagede [...] ution.html
Contrast thresholds data:
http://www.clarkvision.com/visastro/omva1/index.html
Roger
Reply to Anonymous
Roger N. Clark (change username to rnclark) wrote:
>> media and human eyes... keep it coming!
> See:
> Roger
Great resource. Based on that data, I'd conclude that images captured
from my microscope might benefit for 65K x 65K resolution, so I'll use
16 bit D/A's to drive my scanning coils. Of course that kind or
resolution can only be rendered in print. And represents an 8GB file
size. And will take 2 hours to collect.... but might as well build it in.
The figure of 10,000:1 dynamic range in any "one view" corresponds to
about 12 bits. That's pretty much exactly the nominal dynamic range I've
heard quoted for the front end of an SEM.
But it might seems no current reproduction technology acheives quite that.
-Jeff
Reply to Anonymous
Hi Jeff
If you have a set of 40 cards with gradations of gray going from black
to white about 90% of the population will be able to lay them on a table
sorted into the correct order. If you increase the number of cards to 64
about 2/3 will be able to sort them correctly. If you up the number to
80 the number of people that can sort them drops to something like 20%
and by the time you get to 128 cards almost nobody can put them in the
right order. I'm recalling this from memory but the numbers are
something like that.
The sensitivity to brightness for film and the human eye is not
strictly linear. That is even when you give people 128 cards with linear
gradations of grayscale cards to sort there are certain ranges of
brightness wherein they will mostly get it right. So 8 bits (256
brightness levels) will pretty much handle the non-linearty of both the
display and the viewer. That is, most people will not be able to see the
difference between any two adjacent gray levels.
If your next question is - Is it spelled "grey" or "gray"? I don't know
-jim
> based.
> images?
> Thanks!
> -Jeff
----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==----
http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups
----= East and West-Coast Server Farms - Total Privacy via Encryption =----
Reply to Jim
Both are used, but "grey" is used less. The disappearance of "gaol" in
favor of "jail" is now nearly complete :-)
Jerry
Reply to Anonymous
>>Correction: 30:1.
Unless print paper has changed in the twenty-five years since I made
some of those measurements, paper doesn't quite get to 100:1. I have
seen papers with blacks at 2% (50:1). Most papers have about 3% black
reflectance, however (33:1)
At one time I worked on a project finding black coatings for cameras and
other EO sensors. It is amazing how hard it is to get a truly black
black. Even the famed 3M Black Velvet was a 2% reflectance. The only
thing we found was a coating by Martin Marietta that was close to 1%.
The emulsion itself in photographic paper is what creates that
reflection, regardless of how much black silver it has in the emulsion.
I would assume in inkjet ink it would be the binder that holds the
pigment or dye to the paper. With laser printers the toner has some wax
in it.
Reply to Anonymous
>>> Correction: 30:1.
>> 100:1.
> in it.
I once got down to about 0.2% edge-on to a stack of single-edge razor
blades with the backs removed. (I was puzzled at first by poor
performance, but it worked like a charm after being degreased.) That's
about what one gets with a Tyndall tube*. I still have a can of 3M's
Nextel Velvet Black, but as far as I know, they don't make it any more.
(Nextel now means something else.) Kodak's Brushing Lacquer was pretty
good, too, but I think that's also a thing of the past. I'm almost out
of Edmund's flock paper, but that's still available.
Jerry
__________________________________
* I found no web reference to a Tyndall tube, so I figure a brief
description is in order. Tyndall needed a good light absorber for his
ultramiscrope, http://tinyurl.com/66e63 He drew a piece of glass tubing
-- a side tube on his specimen chamber -- to a cone that curved like the
toe of a jester's shoe. The outside of the tube was coated in soot from
a candle flame. Light entering the tube is reflected deeper and deeper
into the small end, suffering a small loss at each reflection.
Eventually, a ray turns around and starts out, again reflecting many
times. By the time it emerges, all those slight absorptions have pretty
well attritted it to zilch.
Reply to Anonymous
> reflectance, however (33:1).
It is a non-specula measurement. 2.0 isn't hard to get to. However,
2.0 is not a good value for making prints with any shadow detail as
it is up on the shoulder. 1.8 OD is a better max value, closer to
2%, as you indicated.
Not only isn't it black, it's yellow, or blue or red ... Black, like
white seems to be an imaginary concept.
Reply to Anonymous
>> See:
>> Roger
> -Jeff
Ooops, 10K:1 is more like 13.5 bits.
But I'm finding a wide range of figures online for dynamic range of the
human eye.
I visited Barco's website in hopes of finding contrast figures for CRTs
and in a white paper comparing CRT and LCD displays, I think they tossed
out a figure of 100:1 for the human eye. 1,000 to one has been mentioned
here as well. The site referenced above so far holds the title for
claiming the widest range.
The white paper also tossed out a contrast figure for CRT's of 3,000 to
one, about 11.5 bits.
The human eye figure of 100:1 is the most surprising. The low contrast
of film is also surprising. I guess it (re film) shouldn't be, I know
that MgO is the most reflective substance as far as diffuse reflectors
go. I forget the figure.
-Jeff
Reply to Anonymous
Photographic paper is often coated with barium sulfate -- baryta --
under the emulsion.
Jerry
Reply to Anonymous
>>> See:
>>> Roger
>> use 16 bit D/A's to drive my scanning coils. Of course that kind or
>> in.
>> I've heard quoted for the front end of an SEM.
>> that.
>> -Jeff
> the human eye.
> CRTs and in a white paper comparing CRT and LCD displays, I think they
> tossed out a figure of 100:1 for the human eye. 1,000 to one has been
> mentioned here as well. The site referenced above so far holds the
> title for claiming the widest range.
> to one, about 11.5 bits.
> -Jeff
Do you mean the contrast ratio of film or of photographic paper?
Photographic paper, especially colour paper, is quite limited. The
contrast ratio of film can be phenomenal, depending on its type. Slow
black and white film reversal processed into slides can have extreme
contrast, and usually has to be bleached down to the point where it
looks reasonable to our eyes.
When considering the contrast ratio of the eye, remember this is an
instantaneous figure. Our pupils are constantly adapting as we scan
around a scene, and the overall constrast we perceive after flitting our
eyes around a scene can be far higher.
Regards,
Steve
Reply to Anonymous
Archived from groups: comp.dsp,rec.photo.darkroom,rec.photo.digital (More info?)
"Steve Underwood" <steveu@dis.org> wrote in message
news:cvjr0u$1l8$1@home.itg.ti.com...
As long as you realize you are talking to amateurs in this field, I don't
think there are any Opthamologists here. All advice worth price charged.
> > > in.
The pixels you need are determined by the spot size of the e-beam and the
size of the object to be scanned. From published SEM photos I would say
2-3 megapixels may be more that enough.
Quite possible. Realize that photography compresses or expands the
range of subject luminance, be it 1000:1 or 10:1 and fits it to the
100:1 standard of the printed image.
The 100:1 range of the printed image is there because that is what the
eye can look at without adaptation: concentrating on the shadows doesn't
result in blinding glare from the white part of the photograph.
Printing evolved to accommodate the human eye. If the range of the eye
were to be 10,000:1 then photographs and printing would be of such low
contrast as to be worthless - we would see it as pale grey on pale grey.
Reply to Anonymous
Carbon lamp black is probably the darkest diffuse
reflector. It's reflectance in the visual range is
about 1.6%:
http://pubs.usgs.gov/of/2003/ofr-0 [...] 3-395.html
specifically:
http://pubs.usgs.gov/of/2003/ofr-0 [...] 8.1533.gif
Spectralon is the brightest:
"Spectralon reflectance material gives the
highest diffuse reflectance of any known material
or coating over the UV-VIS-NIR region of the spectrum."
It is >99% in the visual range.
http://www.labsphere.com/products. [...] &catId=188
Roger
Reply to Anonymous
Speak for yourself ;-). I have written books and articles on
how the human eye operates and detects contrast. But one
need not be a professional to do basic observations to prove
something.
There are several ways everyone can test this. Use stars.
Many people can see the Galilean satellites with their unaided
eyes. Jupiter's moon Callisto averages stellar magnitude 5.5,
and Jupiter -2.5, for a range of 8 stellar magnitudes.
One magnitude = fifth root of 100, or 2.5119, so 8 magnitudes
is 1585 (2.5119^8, where ^ means power).
Next time venus is up high in a dark sky, it will be about magnitude
-4.4. What are the faintest stars you can see? In a dark
sky away from the city, magnitude 6 is possible, and in
very good skies, 7. That is a range of 10.4 to 11.4
magnitudes, or a range of 14,000 to 36,000.
If you have a telescope, you can use star clusters
to test brightness ranges. For example, in the Pleiades
star cluster, I have seen magnitude 14 stars in the
same field of view as magnitude 2.9 Alcyone, for a
magnitude difference of 11.1 or a range of 27,500.
The full moon is magnitude -12.5 and in the city people can see
stars of magnitude 3, and in the country magnitude 5 or perhaps
fainter. That is a range of 15.5 to 17.5 magnitudes,
or 1.6 million to about 10 million! (But the moon is an extended
source, so this comparison might be biased somewhat.)
A million to one is not unreasonable.
Why? I've demonstrated above that greater than 10,000 to one
is easy, yet we still perceive photographs that appear nice and
not of "low contrast." The eye+brain is a contrast detector,
not an intensity detector. And it is non-linear.
Roger
Reply to Anonymous
In article <422E63F7.9070008@qwest.net>, Roger N. Clark (change username to
> about 1.6%:
The BBC's Test Chart No 57 included (includes?), for the purpose of setting
the flare-correction circuitry, a "superblack" rectangle that is actually a
box a few inches deep, lined with black velvet. A small rectangular aperture
at the front opens onto the surface of the test chart. Any light striking
this rectangle enters the dark box and has to undergo several successive
reflections by the black velvet before emerging, thus giving the rectangular
opening an effective reflectance much lower than would be achievable by any
actual surface.
Any value of the output signal above dark current level corresponding to this
part of the chart is deemed not to have come from the chart at all but from
light scattered in the lens, and the circuitry is adjusted accordingly.
Rod.
Reply to Anonymous
"Roderick Stewart" <rjfs@escapetime.nospam.plus.com> wrote in message
news:VA.00000952.00239f52@escapetime.nospam.plus.com...
> setting
> a
> aperture
> rectangular
> any
> actual surface.
Why not just test with the lens cap on?
Reply to Anonymous
> about 1.6%:
The color of the lamp black varies with the source of the paraffin.
North Sea Brent produces a different color than West Texas Light,
produces a different color than ....
This just for plain-ole black paint.
1.6% is quite a bit of reflectance - 1.8 oD, 6 stops down from
white.
Reply to Anonymous
> > setting
> > a
> > aperture
> > rectangular
> > any
> > actual surface.
Test what? The superblack box is for setting flare correctors, which of course
won't do anything if there isn't any flare. All you can test with the lens cap
on is black balance, clamp balance ("pulse cancellation" ) and black shading.
Superblack has to be visible simultaneously with a large area of high
brightness in order to set and balance the flare correctors.
Rod.
Reply to Anonymous
> to
>> >>and
>> about 1.6%:
> setting
> a
> aperture
> rectangular
> any
> actual surface.
> this
> from
Ah - so that's where my licence fee goes......
Reply to Anonymous
In message <112ttcsgeg9pj38@news.supernews.com>,
"jjs" <jjs@nospam.net> wrote:
That should be slightly different, as the black rectangle will pick up
light not meant to be focused in that area (the stuff that lowers
contrast).
John P Sheehy <JPS@no.komm>
Reply to Anonymous
> > this
> > from
Yes, it goes into maintaining broadcast picture and sound quality in various
ways that most people probably don't even know about. It also goes into
training people to be able to do this, and these people gradually migrate
into the ITV and freelance market, where there are hardly any training
courses except manufacturers' proprietary ones on specific items of equipment
unless individuals are prepared to pay for them at costs in the region of
1000ukp per week. Thus, a great deal of the expertise in daily use in
broadcasting *everywhere* in the UK is provided through the BBC.
Rod.
Reply to Anonymous
>>>this
>>>from
> Rod.
But on other side of "Pond" we find FREE enterprise works well.
I never did understand licensing receivers.
Transmitters ( and operators ) yes.
Receivers *NO* !
Reply to Anonymous
"Richard Owlett" <rowlett@atlascomm.net> wrote
> > > Ah - so that's where my [BBC]licence fee goes......
Nothing comes for 'FREE'. Enterprise on both sides of the puddle
is pretty much the same. It's that the British find commercial
enterprise so very tedious. It's just not on, don't you know.
It's to collect fees. It's about the money, it's always about the
money.
No commercials on BBC ... No PBS begging marathons.
I think I would rather pay a fee.
Got cable? -- ~$300/year -- So it's not like it's free over here
either.
Reply to Anonymous
I *AGREE* ;)
I was thinking more along line that if a commercial station could not
send a quality signal they would extremely quickly lose audience and
thus advertisers. I see no reason to insert any arm of government into
process.
> money.
Take it from advertisers not from me.
OK, so in end consumer ends up paying.
I just suspect free market is better filter IMHO ;}
Don't get me started on PBS.
They are just as blatantly commercial as commercial stations.
> either.
Who is crazy enough to have cable &/or sattelite.
There is not that much worth paying for in anycase.
Reply to Anonymous
Archived from groups: rec.photo.digital (More info?)
On Thu, 10 Mar 2005 22:43:31 GMT
In message <n44Yd.573$qW.402@newsread3.news.atl.earthlink.net>
"Nicholas O. Lindan" <see@sig.com> wrote:
> It's that the British find commercial enterprise so very tedious.
Time to move this part of the thread to "Color vs Colour"
Jeff (Heh...)
Reply to Confused
There are 1278 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
