Hi I currently bought a skeleton case and purchased a Phenom x4 965 Black Edition along with a BFG Geforce GTX 275 OC (55 bucks used from a friend) And he ran them 2 of them SLI and I'm wondering what's the minimum W PSU I could get away with doing this? Currently I have a 600W mid-grade power supply. I see all these gaming 800W+ PSU's on ebay for like 50$+ I know they say if its too good to be true it probably is, are these junk? Don't give out the correct wattage, or cheap an inexpensive parts? What's the best PSU I could get for under 100$, then best for under 150$.. I'm looking to stay under 150 dollars as I'm building a budget gaming PC.. Also would you guys recommend popping on the second 275 or recommend saving for a Directx11 card, I mainly game and play World of Warcraft and 1 275 seems to run it fine... Would you recommend just overclocking my current setup and saving my cash? I understand I'm asking alot of questions and I would appreciate any help you guys could give me on this I'm fairly computer literate but only know about as much as I need to .. Thanks in advance for any inquiries...
Thanks, Jake
Thanks, Jake
