Will this ram work in this motherboard?
GIGABYTE GA-970A-UD3 AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard
http://www.newegg.ca/Product/Product.aspx?Item=N82E16813128519
CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ8GX3M2A1600C9
http://www.newegg.ca/Product/Product.aspx?Item=N82E16820233144
Thanks in advance.
1 answer Last reply
More about will work motherboard
  1. Yes it is in spec with the mobo. I would avoid tall heatspreaders, they are a problem with some CPU coolers.
Memory DDR3 AMD
