Hey everyone! So, for a couple of years back I bought the HP Pavilion P6305SC (stationary pc). A couple of months later I found out that the radeon HD 5450 was slowing me down, so I bought a new XFX 6870, which required a new psu with two 6-pin connectors, so I bought the Sapphire PURE 625W. After that I bought a TV card (pcie x1). Today I played Bad Company 2, and with the highest settings my components get very warm, which means that I need more than one chassis fan since the TV card isn't making it any better.
So, to fix this problem I think I need a new chassis with more fans. So I thought the Antec Dark Fleet 10 would fit in good, which is 198 × 497 × 488 mm. But the problem is that I doubt the psu will fit, since it's smaller than the standard (150 × 86 × 140 mm, correct me if I'm wrong about beeing smaller than the standard).
So please help me, will the psu fit? I also wonder if the small motherboard will fit: Form factor: microATX - 24.4 cm (9.6 inches) x 24.4 cm (9.6 inches)
Look here: hp.com/ewfrf/wc/document?docname=c01991243&tmp_task=prodinfoCategory&cc=us&destPage=product&dlc=en&lc=en&product=4119696#N68
(If that doesn't work, try this: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01991243&tmp_task=prodinfoCategory&cc=us&destPage=product&dlc=en&lc=en&product=4119696#N68
Thanks alot! /Theo
Thanks alot! /Theo
