Looking for some suggestion on parts for this build and for information on audio. I am looking to build a HTPC that is quiet and efficent. It will be used primarily for stream, dvr, and bluray. The one part that is absolute is the Ceton card, which I have in hand. I am open to suggestions in the other parts. Mobo, video and audio I am having a difficult time desciding on at all. It is important that the machine is 3d ready and that it has very high quality audio over hdmi. Audio I am at a bit of a loss for. Budget is flexible up to $1500. It will be implimented in a very expensive top end av system. Any help would be greatly appreciate. Thanks in advance.
Win7 Pro 64bit
Centon Infiniti TV4 - http://www.cetoncorp.com/products.php
SILVERSTONE NT06-E - http://www.newegg.com/Product/Product.aspx?Item=N82E16835220033
Western Digital AV-GP WD15EURS 1.5TB - http://www.newegg.com/Product/Product.aspx?Item=N82E16822136810
SAMSUNG Black 12X BD-ROM - http://www.newegg.com/Product/Product.aspx?Item=N82E16827151232
Intel Core i5-2400S - http://www.newegg.com/Product/Product.aspx?Item=N82E16819115075
ASUS ENGT520 Silent/DI/1GD3(LP) GeForce GT 520 - http://www.newegg.com/Product/Product.aspx?Item=N82E16814121438
Win7 Pro 64bit
