Need Build Advice
I almost got the money for this build, but i need someone to help me find a motherboard(i suck at boards).
I want to OC my CPU to 4.5Ghz and i also want to OC my RAM.
My uses will be:
Competitive Gaming(with fraps recording):
CoD4
SC2
WoW
quake
counter strike
Use of the Black Magic intensity shuttle capture card recording fully uncompressed.
Great Video editing for video game montages and anime music videos/AMV's.
7 answers Last reply
More about need build advice
  1. Whats the budget for the motherboard?
    I have a Asus P8P67-M Pro and its great. I cant speak for other brands but Gigabyte and MSI are good too. A motherboard with price of 150 or above should be enough for your needs.
    Biostar TP67B+ LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813138298&cm_re=1155_motherboard-_-13-138-298-_-Product
    MSI P67A
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813130583&cm_re=1155_motherboard-_-13-130-583-_-Product
    Asus P8P67-M Pro
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813131711&cm_re=1155_motherboard-_-13-131-711-_-Product
    Gigabyte GA-P67A
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813128476&cm_re=1155_motherboard-_-13-128-476-_-Product
    Mine cost me 150, now its 125.
  2. Your board is fine if you don't plan on adding another graphics card in the future. If you do then go with the p67x-ud3 since that allows for SLI. I'd also recommend getting a beefier graphics card. The 460 768MB is a great budget card but depending on your resolution I'd up it to the 560 ti or 570.
  3. I have dual gtx 260 on my board. Soon to upgrade to gtx 570 SLI
  4. I would really go for the 560 if I had the other components picked out.
  5. You guys sure i need a different graphics card? Ill be using a 1680x1050 monitor and only want a minimum of 30fps in SC2 and a minimum of 60fps in the other games i mentioned.
    Edit: i plan on getting these hard drives, i just use the western digital to round up the price.
  6. Considering you didn't mention your resolution size until now, I assumed 1920x1080.
  7. Quote:
    If your resolution is only 1680x1050 then 460 should be fine especially if you are only wanting 30fps.
Build Systems Product
