M mosh112 Distinguished Oct 12, 2010 18 0 18,510 Nov 14, 2010 #1 Would there be any problem replacing the antenna from my NETGEAR WG311T (108 Mbps Wireless PCI Adapter) with a 7dBi one, with a pigtail connector (like this)? It's a tower system on the floor and I'd like to get a little better signal.
Solution Emerald Nov 14, 2010 as long as the connector is the same size there should not be a problem. having the router/access point in an elevated location will help, too.
Emerald Titan Aug 28, 2005 15,927 10 70,865 Nov 14, 2010 Solution #2 as long as the connector is the same size there should not be a problem. having the router/access point in an elevated location will help, too. Upvote 0 Downvote Solution
M mosh112 Distinguished Oct 12, 2010 18 0 18,510 Nov 21, 2010 #3 Best answer selected by mosh112. Upvote 0 Downvote
