Hello
From Intel specifications Socket 775 and 771 have identical (outside) physical dimensions:
http://www.intel.com/Assets/PDF/designguide/302666.pdf
cf
http://www.intel.com/Assets/PDF/designguide/313871.pdf
So, are Socket 771 & 775 cooling solutions interchangeable. Or, is there a specification somewhere for their respective motherboard fittings which are sufficiently different to make them incompatible? If the latter, what are the motherboard fitting specifications for cooling solutions and could a 775 solution be adapted to fit a 771 processor and motherboard?
Many thanks.
Regards,
Morgan
cf
Many thanks.
Regards,
Morgan
