Archived from groups: comp.sys.laptops (More info?)
ricky78 <rstewa@acxiom.com> wrote:
: Hi.
: I have recently got a NetGear ADSL Firewall router as I have just got
: Broadband, Model is DG834.
: However I have moved my PC out of the room which had Telephone
: connection point due to it being refurbished.
: I want to make my Broadband access wireless and have heard of something
: called a wireless bridge?
: Could someone explain what I have to do to make this happen?
Not quite sure what you want to do. You want to make your broadband
connection wireless? For that, you will need a wireless access point
(WAP), which you can get for as low as $20. Then you slap that onto
the existing network. Once you set this up, you will be able to use a
laptop within your home via the wireless connection.
Most WAP's you would buy today already have a DSL router (but not the
modem that yours has). What you're looking for us usually called a
"wireless router" even though in your case all you need is the WAP
that is part of that.
Example of what you need: Netgear WG602. But any other wireless
router would work too.
If this isn't want you want to do, what else do you mean?
Andrew
----> Portland, Oregon, USA <----
----> http://www.bizave.com <---- Photo Albums and Portland Info
----> To Email me remove "MYSHOES" from email address
"ricky78" <rstewa@acxiom.com> wrote in message
news:1115903943.920299.110830@o13g2000cwo.googlegroups.com...
> Hi.
> thanks
> rich
If it's a *very* recent purchase, return it to the store and get a wireless
version, such as the WGR614 from Netgear, or pick any other vendor.
