I have recently decided to build a new pc, because all I have at the moment is a macbook laptop.
Here are the components which I have purchased either from scan, overclockers or ebuyer.
NZXT Phantom Enthusiast Black Full Tower Case
Intel Core i5 2500K Unlocked, 1155
Gigabyte P67A-UD4-B3 Rev1.1 Motherboard.
Corsair Hydro Series H70 High-performance
Gigabyte GTX 560 OC 1GB GDDR5 Dual DVI Mini HDMI Out PCI-E Graphics Card
8GB DDR3 1600MHz (2x4GB) Corsair Vengeance Blue
OCZ Agility Series 60GB 2.5" SATA-II Solid State Hard Drive
Western Digital Caviar Blue 500GB SATA 6Gb/s 16MB Cache - OEM
Corsair 750W HX Modular PSU
Asus Xonar DG 5.1 PCI Surround Sound Card
Tenda Wireless-G PCI Adapter
I will try and explain as best as I can what the problem is. I am also uploading a video right now.
Firstly, when assembled everything, the BIOS would not load up and all I get is the phase lights which flash every 4-6 seconds or so. Secondly, the CPU cooler, H70 does not fit the the motherboard, it gives me instructions for various sockets and that I tried using the 1156 socket instructions however i could not get it to line up, and I could not install it (the mounting bracket which is placed behind the motherboard does not fit properly and that I followed the instructions extremely carefully which I spent over 2 hours just trying to fit the H70). Therefore I just removed the back mounting bracket and just used the nuts and screws to securely fix the H70 cooler (holds very firmly)
The phase lights I have mention state that 'The number of lighted LEDs indicates the CPU loading. The higher the CPU loading, the more the number of lighted LEDs '
I am thinking it is a motherboard or cpu problem?
Ive tried using the follow memory slots
DDR3_1 and DDR3_3 slots
DDR3_2 and DDR3_4 slots
DDR3_1 and DDR3_2 slots
A single DDR3_1 slot
I have searched around on the net and found a few people with the same issue as me, but when I try their solutions which worked on their setup, mine did not. Some of the solutions were using both 24pin and (2x4)pin(CPU) cables connected from the power supply to motherboard, changing the memory slots, using standoffs (which I use on the motherboard, not sure If I am doing it correctly).
Ive tried just using the power supply, motherboard, CPU and I get the same results. I cannot even get the bios screen to load up, there are no sounds coming from the motherboard when I try and boot up. Am I missing something obvious here?
If anyone can point me in the right direction, that would be greatly appreciated.
Thanks,
Thanks,
