GPU overheating (HELP PLZ)
  • Radeon
  • GPUs
  • Cases
  • Computer
  • Graphics
Anonymous
March 2, 2011 4:45:56 AM
60 to 70c idle.....
People at Geek Squad told me the computer had good case air flowing
they said my old 4890 was a faulty card...
that card reached over 100c and I couldnt use it
now my 5770, which i used for almost a year, longer than 4890 which 4 months
also has high idle and load temps
it started when i got the card but i didn't care
its still the same now
my house is cold, not warm
I dont see any problems..
HELP
More about : gpu overheating plz
March 2, 2011 5:19:52 AM
just arrange a good cooler in your case and youre done,there is nothing you can do rather than this.
m
l
Anonymous
March 2, 2011 5:30:09 AM
How can I do that? I'm a noob at this lol.
m
l
March 2, 2011 5:27:11 PM
Did you overclock anything ?
Geek squad = Best Buy = Best Buy Computer = BAD BAD BAD POWER SUPPLY.
It might just get too much juice and its heating.
What is the case you are using and the powersupply ?
m
l
March 7, 2011 11:06:28 AM
First off, the 4800 series runs notoriously hot. Second, what kind of air flow do you have by the video card?
I got a Dell from Best Buy and the case had decent airflow, but the video card was 1" from the bottom of the case and was only a single slot videocard. All it did was circulate hot air. It ran 108c at load.
m
l
