MOBO red led on, PC wont power on
Last response: in Systems
- PC wont power on, CPU led red Forum
- SolvedAsus Z87 Pro Mobo shows Q-Code A0 and Power LED glows RED Forum
- Rendering PC POST CPU LED light on mobo is red Forum
- Pc went Dead power led blinks and power supply has a red led on Forum
- Asus P8Z77-V PRO won't power up... just the red CPU LED. Forum
- SolvedRed LED Light and pc wont boot up. Forum
- New PC build won't post, red CPU led lit, Fans work, GPU logo lit, everything plugged in Forum
- PC won't boot red cpu led and screeching Forum
- pc power on but nothing on monitor and no red led light Forum
- Watercooled pc wont boot and has a red cpu led Forum
- CPU Led on my PC is red and Displays won't detect my PC HELP! Forum
- SolvedHelp! New PC build won't boot up, only sign of life is green mobo LED... Forum
- PC won't boot RED L.E.D shows,no beeps,no signal on monitor Forum
- SolvedSystem won't power up. Mobo LED is on. Forum
- SolvedADVICE? Dell Dimension 4550 Won't Power On - Blinking PSU & Mobo LED's Forum
- PC won't boot, but fans and LED's power on Forum
- PC, won't boot, restarts once, no display or beep or even power button led. Forum
- SolvedRed LED on motherboard CPU when power starts on new build Forum
- Power LED on mobo blinking, won't boot Forum
- (Help!)Asus H61M-Plus Mobo, LED lights green, But PC wont start Forum
- More resources
Anyway from the looks of it you need to have the power and reset connected on your F_panel which is at the very bottom right of your motherboard to the right of your 3rd usb and below your last SATA II port. It is supposed to be:
seems like the 24pin wasn't connected properly, had a piece of melted plastic that made it difficult to fully connect ._. out of all the possibilities
