Hi guys
I built my own system and noticed GPU/CPU heating up while playing Rift. I was wondering if you guys had any ideas on what I could do to remedy the situation. Sometimes I get CPU overheat messages during boot up when I checked temp in bios it was 86 Celsius. My Bios setting are basically default and the system is not overclocked...yet. Here is my system:
Win 7 64 Bit
Case Antec 900
Rampage 3 Extreme MB
G Skill Ripjaws F3 12800 CL7Q 8GB Ram
I7 960 3.2 CPU...stock cooler...ordered Cooler Master Hyper 212 Plus to replace it though...hoping this helps a lot
Giga GV-R587SO-1GD GPU
Coolmax 950 watt PSU
OCZ SSD
I ordered 4 new case fans to replace the 3 stock ones and to add the optional side fan to blow directly on GPU. Also got particle covers for the fans as I would like to blow out dust less frequently. I also ordered the Cooler Master Hyper 212 because Maximum PC said it was a great CPU cooler. I am hoping these changes will have a positive effect.
I would like to overclock the system a bit if I can resolve the heat issues...can anyone give me advice for that? Never played with overclocking before.
Win 7 64 Bit
Case Antec 900
OCZ SSD
