Proposed system specs:
Intel Core i7 2600K 3.4GHz
Gigabyte P67A-UD3R-B3
Kingston DDR3 1333 CL 9 KVR1333D3N9/4G (8GB) 4GB x 2
Intel 320 Series 120GB
Samsung F3 1TB
Coolermaster Hyper 212+ or 3R System IceAge Prima Boss II
Asus HD6970 2GB EAH6970 DCII
Coolermaster CM690 II Advanced
Seasonic X-660 660W
Asustek Xonar Essence STX
Currently no plans for overclocking!
The main components I have issue with right now are the RAM, PC case, and CPU cooler. I plan to do some extensive multi-tasking ie. running multiple tabs in my browser, streaming video/music, torrenting stuff, with a few MS office documents open. Will my RAM set up be sufficient for this? I want it to be absolutely lag free. Of course I'm also going to be doing some gaming, mostly MMO first person shooters that aren't too graphically intensive, and also games like Portal 2, Assassin's Creed II, Dawn of War II.
I'm open to more suggestions for good and reliable CPU coolers also. My first choice was the noctua NH-D14 but since I won't be overclocking I've decided to go for a more affordable cooling solution.
And finally, with regards to the casing. I'm looking for alternatives with good build quality and cooling. I have heard that the panels of the K62 don't fit that nicely together and I don't really like the idea of that. The front panel USB and headphone jacks are also not located on the front at all but rather on the top, making them a potential sink hole for dust. I'd prefer a case that has these on the front panel itself.
All input is welcome! Thanks.
Edit: Updated case choice
Samsung F3 1TB
Seasonic X-660 660W
