Archived from groups: comp.sys.laptops (More info?)
I have a Dell type 4E369 battery module for the Latitude C400 laptop.
When I put my finger on the test spot, it lights up as 80% charged. But
when I put it on the computer, it instantly gives me a low battery
warning.
The computer is obviously recognizing that it exists, since it does run
a little without the AC adaptor. But it won't use the power that is
supposed to be available.
Any ideas why it would do this? Anything I can do to fix it?
I have two other batteries that work fine, so it shouldn't be the
computer.
Read your post as you answered your own question. Pitch the battery.
<friesian@zoocrewphoto.com> wrote in message
news:1116141927.556889.81670@g47g2000cwa.googlegroups.com...
> warning.
> computer.
laptop.
But
> > warning.
run
> > computer.
Umm. Thanks.
I was hoping to see if there is a way to fix the battery, as in clean
the connections or something. It seems a shame to toss out a battery
that is charged and seems to be working. They are expensive to replace,
and there are times when I must go a whole day without a power supply.
If I toss this battery, I will be spending $99 + shipping to replace
it. I think it is worth it to try and figure it out.
> laptop.
> But
>>>warning.
> run
>>>computer.
> Umm. Thanks.
Primary failure mode is increased cell series resistance. The charge is
in there, but you can't get it out at a voltage that the laptop can
tolerate.
You have two options:
1) throw it out
2) mess around with it for as long as you care, then throw it out.
Turns out that a laptop COULD be designed to tolerate somewhat higher
cell resistance, but that would negatively impact extremely lucrative
battery sales.
mike
Return address is VALID but some sites block emails
with links. Delete this sig when replying.
Wanted, PCMCIA SCSI Card for HP m820 CDRW.
FS 500MHz Tek DSOscilloscope TDS540 Make Offer
Wanted, 12.1" LCD for Gateway Solo 5300. Samsung LT121SU-121
Wanted 12" LCD for Compaq Armada 7770MT.
Bunch of stuff For Sale and Wanted at the link below.
MAKE THE OBVIOUS CHANGES TO THE LINK
ht<removethis>tp://www.geocities.com/SiliconValley/Monitor/4710/
is
> tolerate.
> 1) throw it out
I'm really confused. How can the battery be running at a different
voltage, so that the computer can't accept it, but this battery *does*
run the computer.
Perhaps, I will see how long it runs, but it does run. It just gives me
a warning instantly. Im not sure if it will boot with this battaery - I
will have to check that. But it definitely runs. I had the extended
battery in it yesterday, and it ran low enough that the screen went
black. I tooked it off and put in this one, and the screen popped on. I
saw the warning and dug out my other battery and switched it out.
"mike" <spamme0@netscape.net> wrote in message news:4287F927.2080404@netscape.net...
Date: Sun, 15 May 2005 18:36:39 -0700
... Turns out that a laptop COULD be designed to tolerate
somewhat higher cell resistance, but that would negatively
impact extremely lucrative battery sales.
Hi Mike... While I have no problems with the lucrative battery sales
part, but the ability to tolerate higher cell resistance does
trouble me. As the higher the internal resistance of a given
battery, the less output current it will provide before the voltage
output starts to drop.
And typically many laptops will use anywhere from an amp to 4 or
higher amps. And lets say we have a 12 volt battery. To pull off an
amp, the internal resistance can't be any higher than say 1 ohms. To
pull off 4 amps, the internal resistance can't be any higher than
much less than 1 ohm.
But batteries from time to time does go bad. While I haven't ever
heard that a Li-Ion going bad from higher resistance (Lead-Acid
batteries this is very common if unused after a many months), but I
won't discount that it couldn't happen with Li-Ion either.
Cheers!
________________________________________________________
Bill (using a HP Pavilion AMD 1.2GHZ under Windows 2000)
-- written and edited within WordStar 5.0
This is a Li-ion battery. Do you have any suggestions on what else this
could be?
<friesian@zoocrewphoto.com> wrote in message news:1116216114.056508.27630@f14g2000cwb.googlegroups.com...
Date: 15 May 2005 21:01:54 -0700
else this could be?
Well if it were any other type of battery (especially a lead-acid
type), I'd say just keep charging and discharging. And if this isn't
working, then the battery is junk. But since I've never had a Li-Ion
battery increase its internal resistance before, I have no clue what
you should do with it.
I'd be very curious how this battery was previously treated? Like
did you use the battery power a lot? Or just left it on AC for like
forever? TTYL
Cheers!
Bill (using a Toshiba 2595XDVD under Windows 2000)
> forever? TTYL
Unfortunately, I do not know. I bought the computer used back in
February, and it came with these 3 batteries. I had only tried this
partiucular one before, and I thought it was just dead and put it
aside. Later, when I got the manual, I learned about the test thing
where you put your finger and the dots light up. So, when I realized it
was charged, I put it back in the bag and assumed I just hadn't put it
in the computer properly.
