Yes No
Ads
Tom's Hardware > Forum > CPU & Components > Power Supplies, Cases & Mods > DELL DIMENSION 5000 POWER SUPPLY
Forum CPU & Components : Power Supplies, Cases & Mods DELL DIMENSION 5000 POWER SUPPLY
Hello All,
Does anyone know where I can purchase a Dell 5000 power supply from? The model is:- N305P-00
The number on the back of the tower is:- 345TH1J
Ref No:- NPS-305LGA 9-0a 59 60 hz
Input 200-240v 4-5 a
Thanks Alf Williams
Reply to chloe123
Hello, I have only just got your e-mail but by the time I got to the EBay site the Dell Power Supply had been sold. Thanks for trying Alf Williams
Reply to chloe123
I see in other seller instock but you must check input PSU 220/240 good luck.
www.serversupply.com/products/part [...] pid=128800
Reply to henydiah
Can use basically any standard ATX psu, I wouldn't spend much on it
http://www.newegg.com/Product/Prod [...] 6817371003
Reply to delluser1
There are 1924 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
3930k idles low, boots hot, then cools?
By DJDeCiBeL, 4 hours ago:
Check your temps with HWMonitor, Core Temp or RealTemp. SpeedFan seems to be wrong more...
Best offers
Top experts
