Solved
4pin to SATA power cable
hi
I recently upgraded my computer, however I realize my PSU SATA power cable is not long enough to each DVD-ROM which requires SATA power connection. Can I use 4pin-SATA adapter? is it safe to use adapter? or should I buy SATA exntension cable?
thanks
4 answers Last reply Best Answer
More about 4pin sata power cable
  1. Best answer
    When to buy new dvd drive ussualy include cable adapter power , it will Save and now problem
    Like this :
    It's OK and fine
  2. Isee. okay thanks.
    yeah I remember my old dvd rom use 4 pin power connector with IDE cable.
  3. Best answer selected by oajlu.
  4. yes 4 pin molex to sata adapter is safe to use.
Power Supplies SATA Power Cable Components
