Hello Everyone,
I have recently realized my interests with computers. And to start with i had started with assembling my own pc, the pc had been assembled and it is more than one month since being assembled. Everything works fine accepts games, which makes me wonder if my pc is stable even though i thought there might be a problem with GPU and had given it back for replacement which i will receive by next week. But still it makes me wonder if my assembling was right or wrong. Below is my configuration: -
Intel i5 2400 - 3.1 ghz processor
Intel DH61WW Motherboard. Specification link: - http://www.intel.com/support/motherboards/desktop/dh61ww/sb/CS-032148.htm
Corsair DDR3 4gb Single channel Ram 1600 MHZ (even though my motherboard runs the ram at max speed of 1333 mhz, everything if fine with the RAM - have done memtest also)
Galaxy GTS 450 1 gb GDDR5
Cooler Master 500W PSU
The issue with gaming is that the pc gets stuck when playing for 2 or 3 minutes, sometimes the graphic cards kernel used to crash and recover due to which i use to get blank screens. There is no heating issue, as i have checked with core temp and during gaming the cores temperature have only reached 65 to 70 degrees max. I want your help in the following queries: -
Can anyone go through my configuration and let me know if there are any issues you are aware about with compatibility of the mobo and the other hardware?
Can anyone also let me know what is the proper way to apply the thermal cream for my quad core processor?
Your suggestions would be of great help to me. Thank You.
