Background:
1.) I am using the i7-2600k to take advantage of the Hyper Threading Tech in the processor over the 2500k.
2.) I would like to overclock some.
3.) I do not know enough about the difference between SLI and Crossfire to choose one way or the other but this motherboard / gpu combo was recommended to me.
4.) I use Adobe CS5, Ableton, and and Visual Studio 2010 the most and do not game.
Questions:
1.) Will this PSU be suitable if I add an additional GTX 570 later on in SLI?
2.) Should I be thinking CrossFire or SLI?
3.) What about the "newer" Z68 Mobo, better than P67 for my needs?
4.) Should I use a better cooler for the CPU than the stock one?
I'm still completely flexible with changing this build around. I like the idea of being able to scale up to 2 video cards later on so I would like to keep a mobo that atleast allows for that and also a PSU powerful enough to support that.
CPU – $315
Intel I7-2600k (3.4ghz, dual-quad core, hyper threading)
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115070&cm_re=i7-2600k-_-19-115-070-_-Product
Mobo – $180
Asus P8P67 Pro (REV 3.0) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131703&Tpk=p8p67pro
RAM - $95
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428&cm_re=g.skill_8gb-_-20-231-428-_-Product
Main HD - $121
OCZ Vertex 2 OCZSSD2-2VTX60G 2.5" 60GB SATA II MLC Internal Solid State Drive (SSD)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227704&cm_re=vertex_2-_-20-227-704-_-Product
Secondary HD - $60
Samsung Desktop Class Spinpoint F3 1 TB SATA 3.0 Gb-s 32 MB Cache 3.5-Inch
http://www.amazon.com/Samsung-Spinpoint-3-5-Inch-Internal-HD103SJ/dp/B002MQC0P8/ref=sr_1_2?ie=UTF8&s=electronics&qid=1304993558&sr=8-2
GFX Card – $355
EVGA GeForce GTX 570 (Fermi) 1280MB 320-bit GDDR5 PCI Express 2.0 x16
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130593&cm_re=gtx_570-_-14-130-593-_-Product
PSU - $90
CORSAIR Enthusiast Series TX650 V2 650W ATX12V v2.31/ EPS12V v2.92 80 PLUS http://www.newegg.com/Product/Product.aspx?Item=N82E16817139020
CASE – $100
COOLER MASTER HAF 922 RC-922M-KKN1-GP Black Steel + Plastic and Mesh Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119197&cm_re=cm_922-_-11-119-197-_-Product
ROM - $70
SAMSUNG Black 12X BD-ROM 16X DVD-ROM 48X CD-ROM SATA Internal Blu-ray Drive Model SH-B123L LightScribe Support – OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151222&cm_re=blu_ray-_-27-151-222-_-Product
Monitors – $180 x 2 = $360
ASUS VH238H Black 23" Full HD HDMI LED Backlight LCD Monitor w/Speakers 250 cd/m2 ASCR 50,000,000:1
http://www.newegg.com/Product/Product.aspx?Item=24-236-117&SortField=0&SummaryType=0&Pagesize=10&PurchaseMark=&SelectedRating=-1&VideoOnlyMark=False&VendorMark=&IsFeedbackTab=true&Page=2#scrollFullInfo
System Total: $1386
Add the monitors @ 360 for both
$1750 before taxes.
Questions:
CPU – $315
Mobo – $180
RAM - $95
Main HD - $121
Secondary HD - $60
GFX Card – $355
PSU - $90
CASE – $100
ROM - $70
System Total: $1386
$1750 before taxes.
