D
Deleted member 362816
Guest
Mobo-Biostar TA790GX 128M Motherboard
link- http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4408236&CatId=3504
cpu-9850x4
link- http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4082332&CatId=3496
cpu cooler-cooler-master V10
link-http://www.newegg.com/Product/Product.aspx?Item=N82E16835103056&Tpk=coolermaster%20v10
Ram- Wintec amp 4gb ddr2 pc6400----4gb gskill ddr2 pc6400
Video card- BFG gtx 260 core 216 55nm--with evga backplate
Link- http://www.newegg.com/Product/Product.aspx?Item=N82E16814143155
Case- Xion axp 600
Link- http://www.xionusa.com/Product-case-AXP600.asp
psu-none
hdd- 500gb Wd blue
OS- windows 7 64bit
So I had to remove the hot sway hard drive bay area to fit the v10 didnt bother me, this is a bunch of old parts laying around so i though hell why not build something decent. From the specs listed here I do think it would be an ok gaming computer for someone that wanted to play games at mid settings or games like guild wars-wow etc.
I need to find a power supply that will have no issues powering this i know that this TEC unit on the v10 does take a considerable amount of power so give me some recommendations the cheaper the better.
cpu-9850x4
Case- Xion axp 600
psu-none
hdd- 500gb Wd blue
OS- windows 7 64bit
