I just can't set-up my wireless home network - there is a problem with the "Connection Status".
I am running Windows XP SP2 on an ASUS P5GD2 Deluxe motherboard (with embedded WiFi-g WLAN adapter).
I have installed the necessary drivers and utilities: this seems to have gone OK.
[I am trying to use the WiFi-g as a Software Access Point].
The WLAN card is recognised in the Device Manager, and no apparent conflicts exist.
>>>BUT - under Network Connections, the WLAN icon shows a problem does exist (yellow triangle with exclamation mark), and the words "limited or no connectivity".
Under "More Information" is stated "This problem occurred because the network did not assign a network address to the computer".
Repairing the connection does not fix things: the problem persists.
So, what is going wrong and how do I resolve the problem?
Wireless networks are very dificult to set up - there are so many things that can go wrong. How far away are the two PC's apart? Although wireless components are advertised as having connectivity over 1500 Mtrs our experience is that it will drop to 60 - 80 feet once you install them in an office or home and put walls in between. Have you set the wireless type to ad-hoc or infrastructure? Have you checked the channels are set to the same channel? Are you networking more than 2 PC's? Have you set the SSID and is it the same on both? If you think we can help you visit www.barrada.co.uk for our contact details. If you don't get us leave a message for us.
You don't setup PC's as AP's. Well, there is linux software that will emulate this and perhaps there is not windows software that can mimic an AP but for PC to PC you run the card in Ad Hoc. A peer to peer WLAN vs an AP/Client infrastructure. So, setup your card in Ad Hoc. You'll need to setup the IP data yourself unless your running something like ICS on a box to share your internet connection. That box will act as a DHCP server, handing out IP's.
Oh, and it's relative I suppose, but WLAN's are easy to setup. For someone not experienced you just have to read the manual and have reliastic expectations. Ignoring the advertised distance specs also may help if that is your expectation for distance.
Don't agree wireless networks are easy to set up - obviously thats not the experience of timclyma!!! Sometimes they work no probs but often they don't which is what you'll find if you do a search for the number of people looking for help.
As I mentioned, it's relative. It's easy for me however I will say I have setup several hundred of them. Not to mention, your dificult and mine may be completely different things. If your competant it is a fairly easy job.
Nah, it's easy for most people. Most solutions are plug the ap in and load the driver on the card. The only thing that might be considered marginally dificult is setting up security. Then if your wireless environment isn't good then some experience can help but as far as the difficulty of setting up the WLAN initially, it's just easy.
if you wanna share internet using your g-card as software AP,make sure ics is enabled, set the g-card on ad-hoc mode, use a static IP on that pc and you should be good to go...
try disconecting the XP firewall, it always hangs up my file transfers....it worked for me then you can re-establish the firewall with the proper access.
EC
<font color=red> Quantum Computers! - very interesting </font color=red>
