Tom's Hardware > Forum > Applications > Multimedia > Problem converting mpeg1 to mpeg4 with Xmpeg
Forum Applications : Multimedia - Problem converting mpeg1 to mpeg4 with Xmpeg
I just downloaded Xmpeg and have been trying to convert some large mpeg1 files to mpeg4 so I can put them on CDs. Everything goes fine except the mpeg4 has a slight stutter or is jerky. I have adjusted EVERY setting I can find and still there is a stutter (it even stutters in the exact same places every time regardless of the variables altered).
I have an excellent system and have had no trouble with DivX playback until now, I must assume it's Xmpeg. Anyone else seen this problem?
- What do you mean it's still plugged in... ZZZT!
Sponsored Links
Have you tried it with FlaskMPEG? They are almost equal, only XMPEG is faster (they say). I believe Xmpeg is buggy. For example, you can't encode audio with MP3 coding with a bitrate of 128KBs and higher.
I had no such problems with Flask.
<font color=blue>Get a T-Bird...
Impressive CPU + House heater in one package. What do you need more?</font color=blue>
Reply to Anonymous
Nope, Flask doesn't do any better... I've run out of ideas on how to handle this.
Reply to Anonymous
I don't know what settings you have played with so I'm just gonna make a couple of guesses.
How fast is your system really? Tom's is saying that using xmpeg and divx 4.1 that you need at least a 900MHz machine. I believe that divx 3.1 is a lot easier to playback. Anyway I have never had any trouble playing back a divx stream on my laptop until I encoded a home video of us Sky-Skiing. It played back jerky. The reason was that the clip was only about a half an hour long and it filled up a 700M cdr so the bit rate was about 3 times what it would have been for a regular movie and the poor old notebook couldn't handle the higher rate. You could try encoding at a lower bit rate.
The other thing you might try is changing the frame rate. I usually try to go with 23.9fps cause that takes up less space but some thing do not like that speed and must be done at 29.9fps.
Option 3 is to try Nandub. Get a copy at <A HREF="http://www.doom9.net" target="_new">http://www.doom9.net</A> or <A HREF="http://www.divx-digest.com" target="_new">http://www.divx-digest.com</A> they both have lots of downloads and information.
Remember if you ain't Muslim you ain't Shiite.
Reply to lakedude
1.2 Ghz TB
I also tried lowering the bitrate as low as 500 kbps and the clip still snags at the EXACT same locations. Never had this problem when I converted clips with Ulead video studio using basicly the same variables. Only problem with Ulead is it's about as stable as a hang glider in a hurricane. I like everything about Xmpeg except for this one problem. And flask still seems to have this same problem.
Reply to Anonymous
There are 1268 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
