I wanted to know if people think my PSU is the problem before I go out and buy one. I suspect that it is, but I'm seeking another opinion first.
First off, I had feared my PSU might be going for a couple of weeks. I've had the same one since 2006, and it's only 300 W. I don't do a ton of high-end stuff on the CPU, but enough for your average wear and tear. The first symptom was my PCI-e graphics card stopped working one day. I ordered a new one, but that didn't work either. A lower power PCI graphics card worked, so I thought maybe my PCI-e slot went bad. I ordered a PCI graphics card that required 300 W, but that did not work.
I've had my lower-powered card in the past couple of weeks, but yesterday the CPU would not boot. Here's what happened:
-Computer froze while using it, turned off computer.
-Turned on computer, and I can hear fans blowing REALLY loud non-stop, like VRRRRRRRRRROOOOOOOOMMMMMM. It doesn't stop, the monitor doesn't come on, and I don't see the orange light on the front of my computer blink like it always does when things start up.
-The DVD drive does have some power to it but has trouble opening sometimes.
-The keyboard never shows signs of lighting up upon turning on.
Another weird thing is that when I unplug the power cable itself from the back of the PSU and plug it back in, the computer acts as though I've pressed the power button on the front of the computer (and I hear the VROOOOOM sound, but with no boot). The PSU never came on in the past when I plugged the power cord in. The green light on the back of the PSU is steadily on when plugged in; no blinking or anything.
I'm familiar with all the typical PC checks. I've took out all my cards. I've reseated the RAM. I've cleared the CMOS. I've held the power button to discharge. I've connected and reconnected every cable in the machine. I tried turning on the computer with no RAM, but there are no beeps -- it's as though the PSU never gets to that point (hoping the MoBo didn't die).
Any help is appreciated! Thanks!
