Hi
I have a Biostar A770E3
http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=450&tab=3
The spec's say the FSB speed is 2600Mhz... I don't get what this means because right now I have it OVERCLOCKED to 2500Mhz (3.5Ghz OC) and normal it runs at 2000 with no OC.
I don't get why the spec's say 2600Mhz, because I have stably gotten it to 2720Mhz (It was just running too hot with stock cooler @ 3.8Ghz)
Can anyone tell me? My guess is that 2600Mhz spec is Biostar's estimated max HT speed, and you can still OC past it, but i'm inexperienced so I can't be sure
