Solved
Hi GUYS..I NEED HELP!! PLEASE SUGGEST!!
Last response: in Systems
I'm a guy into stuff lik video and audio editing. I use PRO tools and Vegas Pro.
I'm on a budget of $600-650.
I decided on Core i5 2400 Sandy bridge. Now Asus P8P67(which i decided earlier) is out of my budget. And it doesn't even give room for the intel's integrated graphics die. So i have to spend extra on a graphics card. :o  :pt1cable:
But i want a motherboard with Firewire port, USB 3.0 and SATA port 6 Gbps with onboard graphics(so that the intel's graphic die won't go wasted). :sol:
Can some one please help me. I have almost cracked out searching online for a solution. Any hot suggestion..I'll really really be grateful..!!
:love:  :love:  :)  :hello:
More about : guys suggest
Related ressources
Before spending any money you might want to look at the prices of a quality sound card if you are serious about audio recording with a computer. Those low latency sound cards ain't cheap!! :o
Ask the community
