Hi!
Been a big fan of the site for a while, and finally got the money together to build my computer.
Ended up going with something like this:
I went with:
ASRock Z68 Extreme3 Gen3
Ivy Bridge i5-3570k
16GB Kingston HyperX Genesis (4x4GB) DDR3 1600
Gigabyte Geforce GTX 680 reference card
Mushkin 120GB SSD
660 watt seasonic modular PSU
Anyway, got it put together, everything powered AFAIK. Turned it on for the first time, and the very handy Dr Debug started cycling through its stuff, stopped at 55, and then beeped at me 4 times. According to the manual post code 55 means "memory not installed". so i took out all my ram, started again, same code. then i installed just 2 4GB sticks first in slots 1/3 then 2/4. code 55 again. I tried with only 1 stick, same problem. I doubt that all four of these ram sticks are faulty, so that should have fixed the problem. Still error code 55, or 0x55 according the the manual.
Im looking for any suggestions at all.
If I uploaded High-Def photos of the inside of my case, could that help in checking if i powered and plugged everything properly?
Thanks guys
I went with:
Ivy Bridge i5-3570k
Mushkin 120GB SSD
Thanks guys
