HD 5770 power compatible w/ ASRock p67 and Sonata IV?
I'm putting together a new system and it's been a while since I've done this. Things have changed a bunch. I'm fairly settled on these components:
intel 2600k
asrock p67 extreme 6
hd 5770 (sapphire)
sonata IV case
The Sonata comes with a 620W power supply. The 5770 says it requires a 75W 6-pin PCI Express power connector. Does that get fed from the motherboard or the power supply. And if the power supply, does anyone know if that Sonata power supply will have that connector?
thanks!
4 answers Last reply
More about 5770 power compatible asrock sonata
  1. Dedicated gpu's grab power from psu, and yes any modern day psu will incuse a 6pin pci connecter for gpu's.
    Maybe i ask what your primary use for this will be? If your going for gaming your definitely too heavy on the cpu side, and should consider upgrading your video card
  2. '75W 6-pin PCI Express power connector' refers to the cable that comes from the power supply. However all cards will get some (if not all) of the power required delivered via the motherboard slot.
    The PSU that is bundled with the Sonata IV is the Antec Neo Eco 620, which comes with two PCIe connectors and is overall, quite a good unit for its price. So you even have enough connectors to power two 5770s if you ever want to do that, or upgrade to a graphics card that needs two 6-pin PCIe connectors.
    i'll be using it to develop and drive multimedia art apps. i often use feeds from hd webcams, process them, and spit those out to multiple screens in real time. the gfx are almost always 2d, but i tjought the 5770 miht be nice for its multiple mon support.
    youre right on cpu...im now looking at the 2500k for the cost savings, but because i'm doing processing i do need decent speed.
  4. Actually if your going to be doing a lot of video editing and rather cpu intensive tasks like that then you'll actually benefit from the i7's extra threads over the i5. Its $100 but still an extra value.
    Heres a comparison for the 2 so you can get an idea of the difference the extra threads will have on video encoding etc.
    http://www.anandtech.com/bench/Product/287?vs=288
New Build HD Power Supplies ASrock Power Compatibility Systems Product
