Hey, all. I've been milling around the forums for a few months now looking for a parts list, and I finally got one... then I found something else that looks waaaaaaaaaay cheaper. Anyways, here's what I'm considering:
Barebones kit:
http://m.tigerdirect.com/m/http/www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=176314&CatId=333&vm_p_show_specs=1&vm_v=q1.aaDrL8
GTX 570:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130593&cm_re=gtx_570-_-14-130-593-_-Product
Okay. My first question is: do you think the PSU in the kit will have enough juice for the 570 (the wattage is right, but I have a feeling that there's more to it than matching the wattage)? Also, I'm a little worried as to whether the GPU will actually fit in the case. The case dimensions are 18.60" x 7.50" x 16.90" and the GPU dimensions are 10.5" x 4.38". I'm new to the world of DIY, so I'm not quite sure how the mobo is oriented and I don't know which dimensions to compare.
Last (and possibly most important) question: assuming that everything here works, what kind of gaming experience am I looking at? My goal is to play games maxed out at 1900x1080 with full AF and 4x AA. Can I get 30+ frames from all current games with these setting on this rig? I want to play demanding, current-gen games. Does this sound reasonable?
Thanks a lot for your help, everybody!
Barebones kit:
GTX 570:
