Only stereo sound and no surround sounds out of my Xonar HDAV1.3 Delux
Last response: in Components
August 11, 2011 10:08:45 AM
Hi,
who can help me?
I have a xonar hdav 1.3 deluxe sound card and have the latest drivers installed.
When testing the speakers i only get sound from left and the right front speaker.
The left and right surround, center and woofer don't give any sounds. (analog)
I have checked everything multiple times to make sure there isn't a problem with the speakers or cables. They work fine.
All cables are connected to the right connectors
Who can help me?
I have windows 7 x64.
MS H61M-E33 with intel i3-2100
4 Gb DDR3
Testing the speakers with the asus utility and the utility from windows 7 are giving the same rusult, only stereo sound ...
I have disabled the onboard audio in the bios
August 11, 2011 12:31:55 PM
What speaker system do you have? Check to make sure that it is in surround sound mode. I had the same problem with my Logitech system until I changed the settings.
August 11, 2011 4:38:12 PM
Might be the speaker system. Just for kicks, test with GX mode set to the opposite of whatever it is currently set to. [GX mode is basically hte directsound emulator. Enabling it is how you get surround sound in DirectSound games. I doubt thats the issue, but it doesn't hurt to check...]
August 12, 2011 8:47:13 AM
i have the teufel concept 300 speaker system.
i tried connecting other speakers to the connector's, but that doen't work either ...
August 12, 2011 12:29:00 PM
Check the settings on your decoder. Make sure that it is set for surround (or 5.1 channel) sound.
August 12, 2011 12:33:50 PM
this speaker system doesn't have a decoder ...
they are just pc speakers ...
August 12, 2011 5:11:45 PM
Can you post a screenshot of the driver control panel?
