Changing Fan Speed? (SATA -> MOLEX)
Last response: in Systems
Related ressources:
- ForumConnecting antec 1200 fans when PSU doesn't have a molex cable
- ForumChange a 3 pin fan plug, to 2 pin molex {using 4pin molex plug}
- ForumNeed HELP with MOLEX fan control for OC
- ForumSata power cables same as Molex ???
- ForumHow to Change the Default Fan speed on Two Pin Graphics Card Connector
- ForumCase Fans- 4pin, 3pin, molex
- ForumProblem - 3-pin Mobo Header, but 4-pin Fan Power (not molex )
- ForumBuilt a PC but missing molex
- ForumGigabyte GA-X58A-UD3R SATA and fan connections
- Forum4 pin molex from fans can't connect to 4 pin power molex
- ForumPsu fan speed ??? What the?
- ForumControlling fan speed through 4-pin molex ?
- ForumSATA to Molex Connector for Case Lighting?
- ForumMolex fan to mobo for speed adjustment?
- ForumCase fans into molex connectors from PSU?
- ForumHow to change fan speed in BIOS?
- Forum4-pin (Non- Molex ) Fan controlelr needed!
- ForumDoes a Molex connector provide as much power as Sata Power connector
- Forum4 pin molex to regular usb adapter?? does it exist?? help!
- ForumPower Supply good for cheap price
- More resources
