Sign-in / Sign-up
What Is the difference between Two ati radeon 5870's
  • Radeon
  • ATI
  • Graphics
Last response: in Graphics Cards
March 8, 2011 11:54:39 PM
ok so i orginally wanted to buy the ati raedon 5770 but then i saw the 5870 whic out performed it by alot and i saw an xfx ati raedon 5870 on tiger direct for like 209 dollars which is a good price it has 1gb ddr5 and pci xpress 2.0 and dx11 and all that stuff but then i saw the diamond version of the 5870 for 560 dollars and it has more ram 2gb of ddr5 but what is the difference and which one is good for me .. I want to play most games maxed out like 4x anti aliasing and im going to be using 1 lcd monitor with an hdmi cable or dvi and plan to play on like 1200 x 800 resolution or something is this card good for games and if so what is the difference thanks
More about : difference ati radeon 5870
March 9, 2011 1:27:25 AM
The XFI will be fine for your single monitor at that resolution.
m
l
March 9, 2011 2:08:07 AM
The Diamond AMD ATI Radeon HD 5870PE52G Eyefinity 6 Edition has 6 mini Display Ports only. There are no DVI or HDMI ports on that card.
If you're not intent on setting up a six-display Eyefinity system then skip this one, it's not worth it.
The XFX HD587XZNFC should be fine for your purposes.
m
l
March 9, 2011 2:11:48 AM
Ok thanks
m
l
March 9, 2011 2:12:19 AM
thanks
m
l
