Hello,
I am doing a Ivy-bridge upgrade and i need some help choosing a MB for the build. As my title says i will be Using a i5 3570K, i don't plan to overclock right away but i will in the future so i want a motherboard that will allow me to do that well.
I have a tight budget and i have picked a few MB's in that range. If you have anyother suggestions all my parts will be bought from Newegg.ca and my limit is $179.99 for the board.
Here is what i have picked:
(Intel BOXDZ77BH55K) http://www.newegg.ca/Product/Product.aspx?Item=N82E16813121606
(GIGABYTE GA-Z77X-UD3H) http://www.newegg.ca/Product/Product.aspx?Item=N82E16813128544
(BIOSTAR TZ77XE4) http://www.newegg.ca/Product/Product.aspx?Item=N82E16813138354
(ASRock Z77 Pro4) http://www.newegg.ca/Product/Product.aspx?Item=N82E16813157296
Thanks for you input
