G
Guest
Guest
Hi
I'm trying to install my i7-2600k CPU into a msi P67A motherboard, and lowering the metal arm that holds the CPU in place seems to require all too much force. I'm scared to push it down because I don't want my CPU to break. How much force should the arm require to be put down, if any? Any tips on what I should do? I've tried loosening the screws that hold the arm in place but they're so short I can only loosen them so much until they pop out. Any help?
