Approximate Purchase Date: this week
Budget Range: $1,300 to $1,400 USD
System Usage from Most to Least Important: gaming, trans coding and ripping movies and general office use
Parts Not Required: keyboard, monitor, mouse
Preferred Website(s) for Parts: love the egg but I am always open to a good deal
Country of Origin: USA
Parts Preferences: i5 2500k
Overclocking: Yes – want to have the option for the future
SLI or Crossfire: Yes – want to have the option for the future
Monitor Resolution: 1920x1080
Additional Comments:
I spent a lot of time reading the forum so I think the components make sense. Please review.
Also, I will purchase another GPU (6850) and use two in one or two months (I need to save a little bit more).
SSD will be used for OS and main programs. Larger drive will be used for media and other files.
Recommendations on monitors for eyefinity would be appreciated.
Thank you for reading my post.
Here is what I have.
- COOLER MASTER Centurion 5 CAC-T05-UW Black Aluminum Bezel , SECC Chassis ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119068
- ASRock P67 EXTREME4 (B3) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157229
- SAPPHIRE 100315L Radeon HD 6850 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102908
- Antec EarthWatts EA650 650W Continuous Power ATX12V Ver.2.2 / EPS12V version 2.91 SLI Certified CrossFire Ready 80 PLUS Certified Active PFC
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371015
- Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor BX80623I52500K
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
- Crucial RealSSD C300 CTFDDAC064MAG-1G1 2.5" 64GB SATA III MLC Internal Solid State Drive (SSD)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148357
- G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314
- SAMSUNG Spinpoint F4 HD204UI 2TB 5400 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152245
- SAMSUNG Black 12X BD-ROM 16X DVD-/+R 48X CD-ROM SATA Internal Blu-ray Drive Model SH-B123L/RSBP LightScribe Support (Retail)
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151232
- Microsoft Windows 7 Home Premium SP1 64-bit English 1-Pack - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116986
- Arctic Silver 5 Thermal Compound - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16835100007
- COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 "Heatpipe Direct Contact" Long Life Sleeve 120mm CPU Cooler Compatible Intel Core i5 & Intel Core i7
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065&Tpk=Hyper%20212%20Plus%20120mm
