Been out of the upgrading game for a while and need help. Lend a rusty tech a hand!
I have a stock Gateway dx4831-01e. Kindly do not tell me to buy another PC or question why I'm upgrading. It's what I have and what I'm going with. I want to max it out for gaming.
Specs from Gateway here: http://support.gateway.com/s/desktop/2009/gateway/dx/dx4831/DX4831sp2.shtml#sup_2
Chipset is a Intel® H57 Express chipset which google tells me supports these processors:
http://www.cpu-upgrade.com/mb-Intel_(chipsets)/H57_Express.html
Cross referencing that with what NewEgg has in stock and with Tom's CPU benchmarks, I'm electing to go with an i7-870 found here:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115213
I would appreciate it if someone could confirm if that CPU is compatible with that desktop's motherboard
Just nervous about spending all this money and ordering something that's not compatible.
For extra credit, could someone recommend:
An NVIDIA video card compatible with that board (no SLI). Budget ~$300. Any PCI-E 2.0 x16 would work, right?
An acceptable power supply for that CPU/Vid card. Not sure what wattage I need nowadays. 750? Budget, not sure.
A good fan to replace the stock fan. Budget, not sure.
Thank you in advance!
Ray
Ray
