I am probably the millionth person to post this type of question but here it goes:
PSU: AZZA Dynamo 850W ver. 2.91 SLI READY (this is what i use to power graphics card)
Mobo:GIGABYTE 890FXA-UD5
Graphics card: GIGABYTE AMD RADEON 1GB GDDR5 HD 6850 (eyefinity)
CPU: AMD Phenom II Black Edition.
I am using all new parts. Card plugs into PCIex16 slot 1. its a DVI connection not VGA.
All the LED lights turn on. The 4 fans on the Case + CPU Fan + PSU Fan all turn on. (case glows blue). Everything was installed correctly to my knowledge. ONLY problem seems to lie with the graphics card. I've already marked it for return to NEWEGG but I want to make sure I just need a replacement instead of a return for something better.
I have the card here for at least 24 hrs from this post so I have time to test stuff out. Like I said, all the parts are new outta the box. Graphics card installed last.
