GTX 460 SLI problems
  • Nvidia
  • Gtx
  • SLI
  • Graphics
March 10, 2011 3:41:53 PM
Hello, i recently added a second nvidia GTX 460 to my system, enabled SLi, and i get graphical glitches in games now, and i dont think i even got a performance boost! have tried reinstalling drivers, and even reinstalling the cards!
in games there are white flashing patches on the screen, or flashing grey squares which are slightly see through.
temps are not too bad, never peaking over 60
i have an I7950
6gb of 1600mhz triple channel RAM
and a corsair HX850w psu.
any help would be appreciated, thanks.
More about : gtx 460 sli problems
a b Î Nvidia
March 10, 2011 3:43:39 PM
What brand are your GTX 460s? Also what are your temps?
m
l
March 10, 2011 3:52:05 PM
one PNY and one EVGA, primary card ranges from 40-60,(evga) secondary card ranges from 35- 50 (pny)
m
l
a b Î Nvidia
March 10, 2011 5:20:40 PM
What are the voltages on the 12v rail? How much are the changes on the 12v rail during normal use. If it drops to low or has large changes over a short period of time can make the machines unstable. Are you sure the whole card is cool and not just the core? It doesn't matter much if the core is 60c while the power vrm is roasting at 100c. Overheated vram can cause many visual errors as well.
m
l
March 10, 2011 5:41:06 PM
Uhm im not sure, but the cause could be mixing the brands, EVGA and PNY. i really think that could be a problem
m
l
March 10, 2011 5:42:35 PM
oh dude, try putting the PNY as primary and EVGA as secondary
m
l
March 10, 2011 5:49:02 PM
and another thing. did you test both cards individually on the slots they are in if you SLI. eg. if you have the evga in the top slot and the pny on the bottem slot. did you test both individually on there slots.
m
l
March 10, 2011 5:50:44 PM
i dont believe it is much to do with heat, if i disable SLi, i have no problems at all. (unless with SLi, temps are much hotter?)
the 12v rail doesent seem to change to rapidly, it seems to peak at 4.1v during games, and while not doing any demanding applications, seems to remain under a volt.
m
l
March 10, 2011 5:52:41 PM
jurgens, ive mixed brands with SLi before, with no problems, i dont think it would be that, the cards are at the same clocks with the same memory ect.
and i have swapped the cards round, with no changes.
m
l
March 10, 2011 5:57:43 PM
latest drivers?
m
l
March 10, 2011 6:00:30 PM
Jurgens said:
latest drivers?
indeed.
m
l
March 10, 2011 6:02:44 PM
what motherboard do you have? did you try to update the bios?
m
l
March 10, 2011 6:07:18 PM
gigabyte X58-USB3
i diddn't consider updating the bios, could it be part of the problem?
m
l
March 10, 2011 6:12:10 PM
i really dont know. it could.... if you sli, in wich card was your screen pluged in, primary or secondary?. if you havent tried swoping cables do that now.
m
l
March 10, 2011 6:13:57 PM
okay wait. what power supply do you have?
m
l
March 10, 2011 6:13:58 PM
i will update the bios asap, Ive tried swapping the monitor cable between cards with no change.
m
l
March 10, 2011 6:14:32 PM
corsair HX850
m
l
March 10, 2011 6:17:31 PM
thats more then enough, try the bios and let me know if it worked
m
l
March 10, 2011 6:37:47 PM
If that is your 12v rail then it is way under spec the 12v rail should always be around 12v. Use HWmonitor to monitor the 12v rail.
m
l
March 10, 2011 6:45:40 PM
HW monitor reports the -12V rail to be around 12.1v
m
l
a b Î Nvidia
March 10, 2011 6:51:06 PM
go into the nvidia control panel and FORCE vsyn on for all apps.
m
l
March 10, 2011 6:54:50 PM
Switch your sli bridge connector around.
m
l
March 10, 2011 6:55:36 PM
Don't have the 460, but I did have some flaky SLI problems originally. My problems were entirely isolated to the network driver, and the bridge between cards, It took some time to iron both problems out. Considering the cards worked perfectly individually. Literally the entire fix was the updated network driver for program problems and wiggle the bridge to get better contact for graphics glitches.
m
l
March 10, 2011 6:59:10 PM
enabled that, the graphical problems still remain.
m
l
March 10, 2011 6:59:25 PM
i will try that.
m
l
March 10, 2011 7:07:56 PM
moved the sli bridge connector around, no change.
m
l
March 10, 2011 7:13:39 PM
Wh
at does your 12v rail report.
m
l
March 10, 2011 8:55:04 PM
Create a profile for a specific game where SLI is enabled, then give that game a try. You can use GPU-Z or MSI's Afterburner to monitor both cards at once.
m
l
March 11, 2011 5:12:01 AM
profile's diddnt work.
m
l
March 11, 2011 5:34:21 AM
are there any bios sli settings?
m
l
March 11, 2011 5:48:54 AM
i don't think so.
(not totally sure)
and i recently updated my bios, with no change too.
m
l
March 11, 2011 6:05:23 AM
you should really try to get a same PNY or EVGA card and see if it isnt the mixing brands. i know the brands does not matter. but just to be sure.. mabe its the motherboard
m
l
