Background - 1st time building a computer and VERY confused!
The computer will boot up; however, I have one problem. - My case fans will not power on even though they are attached to my motherboard. I have the GIGABYTE GA-Z68AP-D3 motherboard and a HAF 912 coolermaster case.
Is there an easy way to fix this or test if there is a problem with the motherboard. As a reference, I removed the 4 pins from the fans and used three pins for both.
Any help would be GREATLY appreciated!!!!
Thanks!
Brian
Thanks!
Brian
