Hey guys, just looking for some thoughts on my system build and to make sure everything will work together. I still haven't put the order in so I'm open to suggestions. The system is mainly for gaming.
A few questions:
- I'm looking to overclock the 2600k near 4ghz. Is that feasible with this build (specifically cooler and RAM)?
- Is the free thermal compound decent or should i go with the Thermal Silver 5?
- Is the power supply going to cut it?
- Will the specific Velociraptor and SSD drives be able to run the "Intel Smart Response technology (SSD Caching)"?
- Any point in getting more than Windows 7 Home?
Thanks in advance!
CPU $225
i7-2500k
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072&cm_re=2500k-_-19-115-072-_-Product
MOTHERBOARD $270
GIGABYTE GA-Z68X-UD5-B3 LGA 1155 Intel Z68 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128492&cm_re=z68-_-13-128-492-_-Product
COOLING $105
H70 Water Cooler
http://www.newegg.com/Product/Product.aspx?Item=35-181-013&SortField=0&SummaryType=0&Pagesize=10&PurchaseMark=&SelectedRating=5&VideoOnlyMark=False&VendorMark=&IsFeedbackTab=true&Keywords=%28keywords%29&Page=1#scrollFullInfo
THERMAL (comes free with cooler)
XIGMATEK PTI-G4512 thermal grease
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233069
VIDEO CARD (already own)
HD 5870 (Cypress XT) 1GB 256-bit GDDR5 PCI Express 2.0 x16
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161301
RAM $100
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 1600 (PC3 12800)
http://www.newegg.com/Product/Product.aspx?item=N82E16820231445
PHYSICAL DRIVES $200 + $145
VelociRaptor WD4500HLHX 450GB 10000 RPM 32MB Cache SATA 6.0Gb
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136557
Crucial RealSSD 64GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148357
COMPUTER CASE $60
Antec Three Hundred Black Steel ATX Mid
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129042
POWER SUPPLY (already own)
CORSAIR CMPSU-750TX 750W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006
CDROM
one of the metal boxes that spins cds
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106276
OS $100
Windows 7 Home
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116986&cm_re=windows_7_64-_-32-116-986-_-Product
$225 CPU
$270 MB
$105 COOLER
N/A VCARD
$100 RAM
$200 VRAPTOR HDD
$145 SSD
$60 CASE
N/A PSUPPLY
$100 OS
$1205
A few questions:
Thanks in advance!
CPU $225
i7-2500k
MOTHERBOARD $270
COOLING $105
H70 Water Cooler
RAM $100
COMPUTER CASE $60
CDROM
OS $100
Windows 7 Home
$225 CPU
$270 MB
$105 COOLER
N/A VCARD
$100 RAM
$200 VRAPTOR HDD
$145 SSD
$60 CASE
N/A PSUPPLY
$100 OS
$1205
