Toshiba wireless card issues
I have installed a new wireless card, what do i have to do to get it to work
1 answer Last reply
More about toshiba wireless card issues
  1. when a wireless adapter is properly installed you should have a "Wireless Network Connection" under Start -> Settings -> Network Connections
    Double click the Wireless Network Connection and search for your access point and then try connecting to it.
    If you have no wireless network connection, check device manager for Unknown Device, then download & install the drivers for the appropriate wireless model from the manufacturers web site. follow their instructions for proper driver installation.
Wireless Toshiba Components
