Wireless Card Drops Connection
Atheros AR5007 802.11b/g WiFi Adapter and I am using 7.7.0.199 drivers on 64bit vista on the hp g60-458dx
My problem is my internet will disconnect and stop loading pages until I disconnect and reconnect to my internet I want to know what is the problem and how to fix it
Windows IP Configuration
Host Name . . . . . . . . . . . . : Caitlin-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Peer-Peer
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : socal.rr.com
Wireless LAN adapter Wireless Network Connection:
Connection-specific DNS Suffix . : socal.rr.com
Description . . . . . . . . . . . : Atheros AR5007 802.11b/g WiFi Adapter
Physical Address. . . . . . . . . : 00-24-2C-9C-C1-BA
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::911a:26ca:8e9f:4938%14(Preferred)
IPv4 Address. . . . . . . . . . . : 10.0.1.8(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Tuesday, November 23, 2010 12:27:59 PM
Lease Expires . . . . . . . . . . : Wednesday, November 24, 2010 2:00:04 PM
Default Gateway . . . . . . . . . : 10.0.1.1
DHCP Server . . . . . . . . . . . : 10.0.1.1
DHCPv6 IAID . . . . . . . . . . . : 184558636
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-13-17-80-D5-00-24-2C-9C-C1-BA
DNS Servers . . . . . . . . . . . : 10.0.1.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Local Area Connection:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . : Howardjohnson
Description . . . . . . . . . . . : Realtek PCIe FE Family Controller
Physical Address. . . . . . . . . : 00-1F-16-D8-AA-5D
Tunnel adapter Local Area Connection* 6:
Description . . . . . . . . . . . : isatap.Howardjohnson
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Local Area Connection* 7:
Description . . . . . . . . . . . : isatap.socal.rr.com
Tunnel adapter Local Area Connection* 11:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 02-00-54-55-4E-01
IPv6 Address. . . . . . . . . . . : 2001:0:4137:9e76:2871:144b:f5ff:fef7(Pref
erred)
Link-local IPv6 Address . . . . . : fe80::2871:144b:f5ff:fef7%11(Preferred)
Default Gateway . . . . . . . . . : ::
NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter Local Area Connection* 12:
Description . . . . . . . . . . . : 6TO4 Adapter
2 answers Last reply
More about wireless card drops connection
    I'm sure you've tried the obvious but just in case - could this be the system cutting power to the adapter through non-use in an attempt to save the planet? Control Panel>Device Manager>Adapter Properties>Power Management.
    Yeah I checked this my wireless card is receiving full power and not being turned off by my power settings
Connectivity Connection WiFi Wireless Networking
