Final Thoughts/Advice On Build
Last response: in Systems
May 21, 2011 5:58:50 PM
May 21, 2011 7:26:28 PM
Great case, gpu, and ram. The rest of the build is limiting you on an upgrade path. The motherboard doesn't support SLI/CF in case you wanted to get another card later on and the power supply won't allow that either. You also can't overclock the processor. If that is what you want so be it but it doesn't allow much in the way of upgrading. You'd just have to buy it all again the next time you plan on upgrading.
m
l
May 21, 2011 7:33:32 PM
that psu only puts out like 500w
m
l
